Raymond EASI REACH:
Looking for help with an EASi
I am currently working on an Easi (EZ A 95 03118). The truck does not want to plug correctly in either direction. I am limited on parts since it is my only easi truck. Suggestions from others already and I have swapped out Q1, K2 relay, TM1 & TM2, Firmware, VFC, Power card, System Card and Control hadle and nothing made a difference. I tested drive motor for ground and it had none. The cables from the motor are all new and I inspected each one and there was no issue there.I do not have a troubleshooting manual at the moment but I am supposed to get one in a week. I am just looking for ideas as what to look for to fix this issue. I do not know a lot about these machines and it kills me not to be able to get this running.
  • Posted 30 Apr 2015 20:55
  • Discussion started by hoovermech
Showing items 1 - 15 of 20 results.
Good Morning! I have read and re-read all the post on this topic and a couple things that no-one has asked or thought about...what is the length of the battery cables and what is the condition of the battery. If the battery does not have enough electrolyte/water, then it cannot provide the required counter EMF for the regen to slow the truck. The battery is being used as a "load" or resistor to oppose the EMF when "plugging" or changing direction. Similarly, the same type effect happens if the battery cables are too long, it changes the counter EMF due to the length and the time it takes for the system to sense the opposing force. This may not be what is happening, but worth mentioning. Just my two cents...hope it works out ok for you! Have a great day!
  • Posted 25 Jun 2015 22:50
  • Reply by lifttrainer
  • Tennessee, United States
not what I expected... I'm leaning towards something being hooked up wrong. I wish I could help further but go over all your connections again, something on the power side.
Firmware/vfc could be culprit but that is speculation.
  • Posted 23 Jun 2015 22:25
  • Reply by stam
A1 - A2.5 ohms
S1 - S2 1.2 ohms.
those are my readings.
  • Posted 19 Jun 2015 01:53
  • Reply by hoovermech
What is the field resistance? As I said above it needs to have 1 - 1.5 ohms
  • Posted 17 Jun 2015 05:07
  • Reply by stam
Just replaced Power Card, Regen and Rec2. Still getting the magical code 2F. Is there any chance my drive motor can be causing this issue even though it tests as a good motor?
  • Posted 17 Jun 2015 02:21
I am gonna get another power card and regen. If that does not solve the issue i will concede and have to hire someone else to come fix it. I just can not see what i have done wrong......hopefully it was an issue with a part and nothing that I may have screwed up. Thanks for all of your input so far. you guys have been a big help.
  • Posted 1 Jun 2015 21:30
I have never done that and never had an issue. Changed at least 25 of those things in my career.
  • Posted 31 May 2015 04:10
  • Reply by stam
When you install the regen DO NOT hook up the 2 power cables to the REGEn until after you have let the truck go through self test once. Then hook up the 2 power cables to the REGEN. This allows the REGEN assembly to "fill" the capacitor. I was told this many years ago and have never had an issue when replacing a REGEN assembly.
  • Posted 31 May 2015 03:02
  • Reply by forktech418
yes the power card if malfunctioning can cause the regen to fry.
sounds like the "kit" is in order. Pwr card and regen.
  • Posted 30 May 2015 04:08
  • Reply by stam
Will a bad power card destroy the regen? I have replaced TM1, TM2, Q1, Q2, Power Card, System Card, VFC, Firmware, Control handle, Rec1, Rec2. All of these are new parts but I am wondering if there is a chance that I somehow got a new part that is a lemon. I have no new parts in house and no other trucks like it in the shop to swap out pieces to find the culprit. I can only imagine that something that I purchased has to be bad......has this ever happened to anyone else? The wiring is all correct according to the prints in the book. I have spend way to many hours on this machine.
  • Posted 29 May 2015 23:10
Tested everything using a Fluke meter.... followed examples given in the book. Replaced the regen and still have a 2F. I am ready to give up.
  • Posted 28 May 2015 22:01
May I ask how are you checking the Q1, recs? With diode tester yes?
Are there any shorts to frame, 10K ohm resister is ok at static strap?
  • Posted 28 May 2015 13:28
  • Reply by EasiTek
Yes. I tested Q1, TM1 and TM2 and they are fine. Not sure if I can get an accurate test on Q2 since it is coated.
  • Posted 21 May 2015 22:58
at least now it is telling you the regen is bad.
wiring/power cables in the right spots?
  • Posted 21 May 2015 02:23
  • Modified 21 May 2015 02:24 by poster
  • Reply by stam
replaced everything and now I am getting a code 2F. this truck is going to drive me insane.
  • Posted 21 May 2015 01:45
Terberg YT182
Terberg YT182
KION reports dip in Q1 revenue Frankfurt am Main, Germany
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
