Linde H80D 396-03 (SLOW lift with full load when hot)
Good Afternoon
We have a relatively new machine, its a Linde H80D 396-03 model year 2025 with less than 1000 hours.
The issue we are having is that when the truck is hot and with a full load the lift speed while initially fast slows to a crawl.
Appreciate any suggestions as to what could be wrong.
Kind Regards
James
  • Posted 10 Jul 2026 20:18
  • By James_Brand
  • joined 13 Nov'23 - 8 messages
  • United Kingdom
Hi James,
If the lifting speed is normal when cold but becomes very slow when hot and under full load, I would first check the hydraulic system rather than the electronics.
I would compare the hydraulic pressure cold vs. hot under load and check whether engine RPM remains normal when the fault occurs. A pressure loss when the oil gets hot could indicate internal leakage, a pressure control/relief valve issue, or possibly the hydraulic pump.
Are there any fault codes stored when the problem occurs? Also, does the same problem affect other hydraulic functions when hot?
  • Posted 8 Aug 2026 20:23
  • By Forkdiag
  • joined 8 Aug'26 - 12 messages
  • France
Forklift Diagnostics | STILL * Linde * Jungheinrich * Fenwick
Remote technical support
Contact: forkdiag@gmail.com
France
