2003 Linde H25T LPG with VW 392 engine, I am finding it difficult to find the part number to match the stuffed unit removed without any ID on the case. It has a 9 tooth x 15mm pinion, 50mm cone plus 6mm flange, flange diameter 82.5mm, two mount holes with M12 thread holes to pull it towards the bell housing, total length 265Lx75w mm. It sits between the engine and the counter weight at the rear of the engine. The cone jaw opening angle degree is not always included in the sellers specs, so finding it difficult to comprehend the correct unit I need to purchase. Location Perth Western Australia. Any info greatly appreciated.
Good replies so far. The Bosch 00011110022 is a good starting point. But since you're in Perth and getting the cone jaw angle confirmed is tricky, I'd suggest contacting a Bosch auto-electrical supplier directly and giving them the physical measurements you listed. Most of them can cross-reference by dimensions rather than just part number, which saves you the guesswork on that cone spec.
If you're looking at where to go next with the fleet, the shift toward electric forklift options (https://lindemh.com.au/products/electric-forklifts) has been worth a look for indoor/warehouse use, mostly because the parts headache basically disappears.
Ersatzteilnummer
0001110022
BOSCH
0001110023
BOSCH
0001110045
BOSCH
0001110046
BOSCH
0001110066
BOSCH
0001110067
BOSCH
0001110106
BOSCH
0001110107
BOSCH
0001110108
BOSCH
0001110122
BOSCH
0001110123
BOSCH
0001110126
BOSCH
0001110127
BOSCH
0001110128
BOSCH
0001110129
BOSCH
0001110136
BOSCH
0001110137
BOSCH
0001110138
BOSCH
0001110139
BOSCH
0986014620
BOSCH
0986016240
BOSCH
DRS6240
DELCO REMY
CS624
HC-PARTS
8EA730194001
HELLA
LRS00783
LUCAS ELECTRICAL
LRS783
LUCAS ELECTRICAL
063521101060
MAGNETI MARELLI
943251323
MAGNETI MARELLI
MSN2028
MAGNETI MARELLI
527505
STILL
9710100
STILL
438072
VALEO
455933
VALEO
D7R33
VALEO
Zusammenklappen
OEM-Teilenummer Äquivalent
068911023P
AUDI
068911023R
AUDI
068911023S
AUDI
068911024B
AUDI
068911024C
AUDI
068911024E
AUDI
068911024F
AUDI
068911024G
AUDI
068 911 024 F
SKODA
068 911 024 G
SKODA
068911023P
VW
068911023R
VW
068911023S
VW
068911023SX
VW
068911024B
VW
068911024BX
VW
068911024C
VW
068911024CX
VW
068911024E
VW
068911024EX
VW
068911024F
VW
068911024FX
VW
068911024G
VW
068911024GX
VW
