Linde E18C-02 335 series
tryed to find right scematics for this machine on internet,dont find the right one
serial number H2X335N00229
2002 year model
got some problem with K1 main contactor not turn on
Ps K1 replaced with new one ,coil.winding was broken
first time on this group
  • Posted 21 Jan 2026 23:50
  • Modified 22 Jan 2026 02:26 by poster
  • By haskiruna
  • joined 21 Jan'26 - 1 message
  • Kiruna, Sweden
Welcome mate. On those older Linde units the K1 contactor not pulling in is usually a control side issue rather than the contactor itself, especially if you've already replaced it.
First things I'd check:
Is the coil actually getting voltage when you key on and request drive?
Seat switch, brake switch and direction lever interlocks. If any of those aren't made, K1 won't energise
Fuses and control relay upstream of K1
Wiring back to the controller, sometimes you'll get a break or corrosion in the loom
Those machines rely pretty heavily on the safety chain being intact before the main contactor closes.
If you can't track down the exact schematic, try looking at similar 335 series diagrams, they're often close enough to trace the circuit. This page on an electric forklift range (https://lindemh.com.au/products/electric-forklifts) can at least help you compare general layouts, even if it's newer gear.
If you've got a multimeter handy, start at the K1 coil and work backwards, you'll usually find where the signal drops out pretty quickly.
  • Posted 29 Apr 2026 17:19
  • By AshMazin
  • joined 22 Apr'26 - 8 messages
  • Australia
Autolift E180AT36B-D5-180
TCM FD80Z7
TCM FD80Z7 1990
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
TCM FD80Z7
TCM FD80Z7 1990
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
