Raymond EASI REACH:
Intermittant code 5A then 59
Its for an EASI reach model and have the book but those codes are not listed. I can not duplicate issue but the operator has written these codes down. Battery was at 30% and had the customer change it out to see if it was a battery issue.
  • Posted 21 Oct 2014 05:42
  • Discussion started by tomas_s
  • Bahamas, Bahamas, The
OK found out what the issue was for intermittent code 5A.
Check your static straps!!!
Installed a small chain connected to unit with a hose clamp and unit has been running fine ever since with no issue.
  • Posted 25 Oct 2014 04:19
  • Reply by tomas_s
Found out these codes are for a CAN bus communication issue. The technician I talk to said to check for bad or dirty connection on the A/C motor controller box or vehicle manager. Also said to check the CAN bus resistor. Will post what I find out when I have a chance to put hands back on the truck but know if I did not post this now I would forget.
  • Posted 23 Oct 2014 04:19
  • Reply by tomas_s
ROYPOW
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
edition #1229 - 8 May 2025
