Hyster S60 Lift cylinder disassembly
Got the lift cylinders out and on the bench. Gland nut took some convincing but got those off. Question is does the piston on the bottom of the rod come off? Usually a snap ring or nut on other machines but I don't see anything holding it on. Spins freely though?
  • Posted 2 Apr 2026 05:40
  • By Shortoftime2763
  • joined 2 Apr'26 - 1 message
  • Washington, United States
If you are repacking the cylinder there is no need to try to remove the piston on the bottom just pry off the packing and remove the wear ring replace in the same way. you will never get that off the rod and there is no need. Hope L was of help.
  • Posted 5 Apr 2026 10:07
  • By Scott_
  • joined 16 May'21 - 344 messages
Scott
Look for a hole or small slot where packing is
There is usually a locking wire that you pop up and out a little then turn the end clockwise that works the locking wire out when reinstalling there will be an L shape in end of wire that locks into shaft then turn opposite direction to install locking wire sometimes it is hard to find
  • Posted 3 Apr 2026 04:17
  • By John_Bradley
  • joined 10 Aug'22 - 305 messages
Jb69
Terberg YT223
Toyota 02-8FD25
Zhejiang UN Forklift Co., Ltd
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Terberg YT223
Toyota 02-8FD25
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
Terberg YT223
Toyota 02-8FD25
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
