How to adjust lift chains on Toyota 8FGCU25
I have a Toyota 8FGCU25 that I would like to adjust the mast so the forks don't hit the ground. This truck has a side shift on it if that matters. I'm following the procedure in the manual. I adjusted the chains to move the mast up and have the forks slightly off the ground when lowered and mast vertical. When I raise the mast to the second stage the lift bracket stopper hits the lift bracket. I'm pretty sure that is not good, so I adjusted it back down. How do I get this adjusted so the forks don't drag on the ground when lowered?
  • Posted 13 Oct 2026 05:24
  • Modified 13 Oct 2026 20:02 by poster
  • By Mike_engineer
  • joined 13 Oct'26 - 2 messages
  • OHIO, United States
Hey Mike,
Oh, that's odd; you could try driving onto a 1.25-inch thick beam to see if you can adjust the chains then. If it's a triplex mast, it is definitely recommended to adjust the outer chains first.
Marcb
  • Posted 14 Oct 2026 03:48
  • By marcb
  • joined 10 Jun'14 - 233 messages
  • ANTWERP, Belgium
Marcb,
Thank you. I checked the chain and it was stretched. I replaced them with new chain. I adjusted it again and still have the exact same problem. I simply don't think it's possible to get the forks off the ground in the lowered position with the mast vertical. I actually think I would have to have the lift cylinder shortened by 1/2" or so if I really wanted this.
I did look at the front tires. They are 21" and are worn. They measure 18.5" tall. If I had new tires then I think the forks would not grind on the ground.
Am I missing something?
  • Posted 14 Oct 2026 03:12
  • By Mike_engineer
Hey mike, The chains are overstretched; you will need to replace them first and then readjust them as you described. There are, however, measuring tools available to check the stretch of various chains..
Marcb
  • Posted 13 Oct 2026 14:37
  • By marcb
  • ANTWERP, Belgium
