Hot no start
Starts up fine when cold.Then after warming up and shutting off, lift doesn't want to start until cooled back down
  • Posted 11 Jun 2026 11:00
  • Modified 12 Jun 2026 02:17 by poster
  • By Ben_Patterson
  • joined 11 Jun'26 - 2 messages
Have seen where the vaporizers back low pressure side will actually leak air when warmed up. This. Looses ability to maintain vacuum to operate. Also. If it has the electric slow path solenoid on it, they short hot when hot. Also. Below the mixer, carb. Some were assembled wrong an the heat riser gasket was positioned wrong. The heat riser gasket is first. Then spill plate. Then gasket and etc. should be 3 gaskets. If they are brittle. Change them all out in proper order.
  • Posted 14 Jun 2026 06:59
  • By ron_k
  • joined 2 Apr'15 - 144 messages
  • North Dakota, United States
4kliftman
If possible see if it will fire on starting fluid don't use a lot just spray a little in the air cleaner and see if it starts that would tell you that something shutting down the fuel when hot. I am thinking this truck is on lpg ? if so it uses an assian propane system on the bottom of the regulator is a black valve that is the fuel lock when cranking do you here that clicking also on the top there's another valve it called the slow idea valve it is silver both valves must open to allow lpg to the carb. Also this assian converter would gum up and have trouble starting when cold but your problem is when hot.. If every thing checks out when it does not start try shutting the gas tank off and see if it tries to fire also can you here lpg coming out the air cleaner when it won't start truck might be flooding from the Asian converter. Get back to me and let Mr know.
  • Posted 14 Jun 2026 03:33
  • By Scott_
  • joined 16 May'21 - 342 messages
Scott
  • By Scott_
Scott
It cranks and has plenty of spark, but won't start. Then after waiting 15 or so minutes when the motor has cooled down it will fire up again
  • Posted 13 Jun 2026 23:41
  • By Ben_Patterson
Ben P
After it gets hot does it crank and not start or is it dead.? If it cranks and won't start check to see if it is loosing spark or fuel. get back to me with some more information.
  • Posted 13 Jun 2026 22:15
  • By Scott_
Scott
Not sure if your model is correct? Lift turns on , then won't power up?
  • Posted 12 Jun 2026 02:05
  • By ron_k
4kliftman
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
