This is my home shop lift that i've owned for about 10 years. Lift leaks down with no fluid leaking out. Where do I start to figure out which cyl it is? It has a center main larger cyl about 5" then has two longer cyl about 2.5". At the top of the longer cyl it has a return line(? ) that if it is up and you remove that line it pours out the left one and drips out the right one. I really don't know where to start. I have resealed cyl before (did the tilt cyls about a year ago) I have a full shop to DIY in, Any and all help would be great! Thanks
Edit: Or if any one want to tackle this job I will gladly pay them and supply parts.
