H70FT Can Bus issues
Hello all.
I have 2x of these Hyster L177 H70FTs both with the GM/PSI 2.4 that are both having canbus communication issues. I've tested what I can, cleared codes and waited for them to reappear, and have the following results:
Error codes present on one of them: 2000-12, 100-2, 106-4. JalTest gives can bus addressing error, Oil pressure OOR high, and MAP OOR low errors in that order. 100-2 and 2000-12 both recurring after being wiped last week for confirmation.
Unit has intermittent idle issues. It starts and runs, but stumbles maybe 2/10 times. seeming to improve when the unit gets up to operating temp.
I've ohm'd out the can bus (which is giving 40ohms. low. like there's a 3rd terminating resistor somewhere, but i'm currently flying without diagrams or manuals. so i'm not sure where to begin looking for the mystery 3rd resistor.) I've pulled live data. in fact, the error repopulated while actively connected to the can bus with the jaltest. meaning the can bus is working to communicate regardless of the error being thrown. I've heard that these units have had a known issue with the engine harness and was wondering if anyone has a service bulletin to justify throwing a harness at this thing, or if there's more information to go digging into before trying to shotgun parts at this thing without any confirmations.
Or just general ideas and tips would be welcome. I have a hard time believing that both of these units decided to blow out a VSM simultaneously, and am trying not to "spray and pray".
thanks in advance.
  • Posted 9 Jun 2026 10:23
  • By kmarshes
  • joined 9 Jun'26 - 1 message
  • WA, United States
There was a connector on the backside of the battery box that's tied to the Canbus system that can cause issues as well. If i remember correctly they're not yellow and green wires within that connector. 3 termination can be found on that unit you're looking at. Steering column, near hydraulic breather and also on the old GM engines with the 2.4 the ECU carries one as well. 40 ohms is obviously not correct. It's been awhile since I've touched the older Fortis lifts.
  • Posted 17 Jun 2026 04:18
  • By BirdDog21
  • joined 17 Jun'26 - 1 message
  • Alabama, United States
Jwood@liftone.net
15 Years
Level 5 Tech.
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
SNORKEL A46JE
Terberg RT223
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
