GM 2400
I'm working on a Yale GLP070VX with the GM 2.4 motor. What is the recommended timing belt service and is this an interference motor?
  • Posted 14 Apr 2026 06:46
  • By Greasemonkey
  • joined 10 Mar'22 - 20 messages
Yes, break a belt and get bent valves. These are famous for eating up all the belt drive gears. Front covers are not sealed. Belt change interval 2,000 hrs. Chicagoengines has all the parts for these. When you change out the crank gear, make sure you torque the crank bolt to specs. They will come loose if not.
  • Posted 25 Apr 2026 00:47
  • By Mechabob
  • joined 11 Jun'20 - 7 messages
  • Washington, United States
I would recommend 5 to 7 thousand hours at most. Good luck
  • Posted 24 Apr 2026 03:35
  • By garland_m
  • joined 16 Oct'09 - 225 messages
  • Virginia, United States
Work Hard and Fish Long
Ncn 110TH
Ncn 110TH 2015
Tusk 350CGH20
November 10-12, 2026 - Marina Bay Sands, Singapore
September 16-18, 2026 - Guangzhou, China
The largest butterfly in the world is the Queen Alexandra's Birdwing (ornithoptera alexandrae), with a wingspan of up to 31cm (just over 12 inches). It is an endangered species only found in Papua New Guinea.
