ge ev 200 problems
having continual issues with code 47 and code 53 on ev 200 system. installed new #1REC and new #2 and #5 and still code 47 and code 53.everything else checks good. thinkin card now. Suggestions anyone?
  • Posted 2 Feb 2011 13:03
  • By mudforce
  • joined 17 Nov'09 - 5 messages
  • Alberta, Canada
don`t ask me how i know, but.... check your recs 3, 4 y 7.
if any one of these are not SEMIKRON you maybe have change it.
if your recs are from india (I X R). you need to change it.
try it and fix it.............
your mails please to send the info.....
  • Posted 4 Oct 2012 15:15
  • Modified 4 Oct 2012 15:16 by poster
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
did you find the problem?? I have the same one and it spark a lot when I go from forward to backward... and both motor are rebuilded.. :(
  • Posted 25 Sep 2012 08:55
  • By Martin2000
  • joined 25 Oct'11 - 26 messages
  • Quebec, Canada
Check for short circuit on motor field or short circuit on armature, also check for bad connection between SCR1 and capacitor through scr2, also refer to status code 25 as this may be part of the problem,
Titus
  • Posted 3 Feb 2011 05:37
  • By Titus
  • joined 6 Jul'10 - 185 messages
It could be a capacitor problem espeially if it happens under load.
  • Posted 2 Feb 2011 23:19
  • By controlelectric
  • joined 8 Dec'08 - 70 messages
  • Shropshire, United Kingdom
It takes years to build up trust, and only seconds to destroy it. controlelectrics.uk@gmail.com
Defective motor circuit.
Check motor circuit for open or loose connections.
Check motor brushes for proper seating.
F or R contactor power bouncing open.
Insure that F and R contactor does not bounce
open during vehicle operation (ie: traveling over
speed bumps and dock plates).
  • Posted 2 Feb 2011 13:41
  • By mike_v
  • joined 1 Jul'10 - 190 messages
  • Illinois, United States
mike_retired
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Kalmar DCG16-900
