Crown CROWN WAVE 60-118:
Fault code's
I do look for explain fault code,s of Crown wave 60-118
Fault code 327 and 216
I have no doc of it.
Regards,
TraigoGen
  • Posted 8 May 2021 17:26
  • Discussion started by TraigoGen
  • Netherlands
knowledge about Toyota - BT
Event Code 216
The driver of the main contactor coil is shorted.
All vehicle movement is disabled.
Step 1: Check if there is a short or a low impedance
pull-down between NLC (CA403-6) and -BATT.
* If: There is a short or low impedance
- Then replace the wire
* If: There is not a short or low impedance
- Then replace Access 2/3
Event Code 300 through Event
Code 352
These event codes match Event Code 200 through
Event Code 252.
Step 1: Follow the procedures for the corresponding
event codes; for example, for Event Code 310, follow
the procedure for Event Code 210. If the procedure requires
the checking or replacement of an Access module,
then check or replace the Access 3 module. If the
procedure references the right traction motor, do the
same checks, but for the left traction motor.
Event Code 227
The lift switch is pressed when the vehicle is
turned on.
Step 1: Release the lift switch.
Step 2: Check the lift switch contact.
Step 3: Use a DVOM to check the signal value on the
Access 4 connector.
* If: There is a mismatch between the values in input
and the values read
- Then replace the Access 4 module
  • Posted 10 May 2021 17:20
  • Reply by ivanlinaric
  • Zagreb, Croatia
Feel free to contact me at ivan.linaric@okretnimoment.hr
FOR SALE ON MACHINERY-ONQ
Taylor TT300
United States Pennsylvania
Canada Ontario
Denmark
Netherlands
Featured Business
Rebo Systems has developed a unique in-house label printer that can effectively satisfy all your demands for signs and labels on your materials handling equipment.
“…I'm happy to report that we recently appointed an ideal candidate who found us via the Forkliftaction ad. This speaks volumes from my point of view.” - Hamish Clark, President...
Featured Business
F. Uchiyama
Global exporter of used forklift and construction machinery, servicing over 50 countries.
Xcmg XCB-D20
China
Canada Ontario
China
senior marketing manager
Tompkins Robotics, United States
chief digital officer
Wiferion, Germany
director of dealer development
Toyota Material Handling, United States
director of national accounts
