Hyster H5.00DX:
Excessive engine noise & oil consumption
Hello John
Suggest you contact your local Hyster dealer. Good bloke he is!
  • Posted 9 Feb 2005 21:24
  • Discussion started by adam
  • South Australia, Australia
Hi there
i have 3 x Hyster 5.0DX one of which has just had a major diff/transmission failure. the following was received from the service company.
"spent a bit of time investigating your diff failure yesterday
my conclusion is chain of event -
spider gear thrusts bearing surface wore out first.then went steel to steel and quickly contaminating oil.
Pinion bearing then collapsed destroying crownwheel and pinion.
Have got results back from oil lab for 401 and 985 both with alerts on them for excessive wear and oil contamination
Have checked your oil on site, and strongly recommend you double check with your supplier that it is compatible with HYSTER spec that follows.
Hyster spec :- for differential
SAE 90
API GL-4
The oil you have on site and charted is
Mobil
85w-140
API GL-5"
Spec of oil is very similar.
Hours on trucks range from 17000, 19000 (failed), 23000. Is this an inherrent problem with these trucks? Cost of failure so far $12500. Cost of investigation of remainder at least $5500 each.
  • Posted 7 Feb 2006 14:08
  • Reply by gary_w
  • New Zealand
Hi there
SAE 90
API GL-4
Mobil
85w-140
API GL-5"
  • Reply by gary_w
  • New Zealand
All the advice so far is good.
If you use a regular grade and make of oil try calling the oil company representative, he may have experience of this problem directly and will almost certainly arrange for oil analysis - perhaps FOC. As an ex-rep I can assure you that if you are reasonable and ask for assistance company reps are always pleased to help and advise. Read the brochures and listen to his experience.
Just a thought, do you blow out your air filters with compressed air?
Most filters should not be blown through - you can do it, but you are just making minutely bigger holes in the element and these let through minutely bigger particles, the effect is obvious.
Likewise oil filters, if you change them late the filters are full if dirt and the by-pass valve lets dirty oil re-circulate until the engine dies.
Has there been a change in maintenance systems? The engines have done 2000 to 6000 hours, this a quite a spread but they all died together!
  • Posted 12 Feb 2005 04:21
  • Reply by rod_s
  • England, United Kingdom
I think that the low pressure and the excessive oil consumption is caused by worn out main bearing. To check have the oil analyzed. Your engine is due for general overhauling. You did not mentioned whether it is overheating or not.
  • Posted 11 Feb 2005 11:04
  • Reply by leobert_b
  • Makati, Philippines
Never Say Die! in every sale, life is at stake
An Oil analysis can give a lot info ! If oil consumption is excessive, mostly there is a reason why the engine is worn (dust, no sufficient filtration,......).
Look to the inside of intake manifold , if you can find dust who's scratching on your fingers, engine must be damaged !!
  • Posted 10 Feb 2005 22:55
  • Reply by Parts
  • West-Vlaanderen, Belgium
Lorette, France French equipment maker Haulotte has recorded a satisfying sales rise in the first half of 2021. In its statement to the market, the company notes...
Waukesha, WI, United States Wildeck has appointed Angela Wurtz as its new director of people operations. Wurtz will be responsible for all aspects of...
Inside Forkliftaction
This week's newsletter includes a couple of fleet expansion reports. We find these valuable because they indicate the areas of economic growth - both geographically and in industrial sectors.
But, more importantly, it's valuable to all potential buyers to see who is choosing what - and why. Clearly, some case studies reveal
...Continue Reading
During WWII, while testing the top secret and first jet-engined aircraft by Bell Aircraft, US pilot Jack Woolams donned a gorilla mask and a bowler hat on his head so that any witnesses who reported back would not be believed.
The Open-Air Wax Museum
An odd hodgepodge of wax figures is displayed in a shopping center walkway in Saint Petersburg, Russia.
...Continue Reading
Cannock, United Kingdom Mereway Group has taken delivery of seven Hyster forklifts at its warehouse hub. The new fleet is all on a seven-year contract hire and is...
Surrey, United Kingdom Hyster is the latest to offer integrated lithium-ion battery power in its counterbalance truck range, with the launch of the J2.5-3.0XNL. Engineered around a fully...
...Continue Reading
