you got any response from the official team. please update me
Do you have an electric schematics for this EJE116 (2007)?
I have to do some measurements.
Okay! I´ve sent you an email
Thanks for your quick reply!
13 Disable Watchdog field
faulty
F, H CONTROLLER Replace components Travel no function
14 - Main contactor
notclosed
- Field power stage
cannot be switched on
(DC)
F, H,
F-AC, H-AC
CONTROLLER/
MAIN CONTACTOR
Check wire connection; check main
contactor; check charging connection,
Check field supply fuse,
Replace component.
No travel, hydraulics
Warning symbol
Flashing warning (Else-Check).
15 Disable field faulty;
Illegal address (for AC)
F, H,
F-AC, H-AC
L
CONTROLLER Replace controlpart; replace
component
Travel no function
Hi guys,
I´ve got a EJE116 with a AS2405 box.
Blinking code: 15 and 13
Anyone knows the meaning?
Thanks in advance!
The print in the steering tiller has his voltage, i ordered a new print. So it should work when i install that one. Thx for the info.
Yes, if your saying the steering head or we call the steering tiller. It is part of the can bus.
Control is dead or not Voltage in control.
It fell off a truck, and i wanted to test if it still works, but what you say makes sense. although i thought i connected everything again but i ll have to check it over. When the print in the steering rudder is broken will it also show this error? thx for the reply.
Did you replace any parts recently? This code means it didnt see all the can bus components, controller, tiller head, display, keypad(if installed) Diagnostic port.
