E32 code
Step 1 overheat
where do I start with this? I checked to make sure coolant is full, I checked all wiring, could it be the thermostat? is that a common issue with the unicarriers?
  • Posted 22 Jul 2026 04:17
  • By PeytonN
  • joined 22 Jul'26 - 1 message
  • VA, United States
Peyton
Check the radiator core for dirt blow out the radiator core or if you have a pressure washer clean out the fins in the core and see if it runs hot. Also make sure your belt is tight and antifreeze is full most of the time it is dirt in the fins of the rad no air flow.
  • Posted 23 Jul 2026 12:47
  • By Scott_
  • joined 16 May'21 - 344 messages
Scott
Bolzoni SpA (Group HQ)
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
UN Forklift FB25N1LZ1
UN Forklift FD50T-NJB3
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
