Crown WAV 50-118 Controls Flipped
I have a Crown WAV 50 that was throwing occasional error codes saying left drive motor wiring open or left drive motor defective.
I took the motor out to investigate and noticed the motor was soaked in oil. So, I decided to get inside the gearbox and replace the input & output shaft seals. That was mostly successful.
After that, I cleaned out the motor really good, replaced the brushes, and put everything back together.
Now when I start the truck, she fires up fine, but the controls are backwards in a way. The steering pod left commands throttle forward, turning right puts us in reverse. The throttle steers the truck left and right.
Any ideas on what went wrong? There was only one electrical connector on the motor, and two wires for the brake. The motor connector can only go in one way. I tried the brake wires in both possible positions, but have the same issue either way.
  • Posted 9 Sep 2026 03:52
  • Modified 10 Sep 2026 02:59 by poster
  • By Austin_B
  • joined 9 Sep'26 - 2 messages
  • United States
The motor was reassembled in reverse order. Meaning the positive side of the brushes are now negative. Swap the wiring around.
  • Posted 11 Sep 2026 08:14
  • By ron_k
  • joined 2 Apr'15 - 147 messages
  • North Dakota, United States
4kliftman
Update:
I fixed it.
Not necessarily sure how...
For **** and giggles, I reversed the ML + & - this morning. Unfortunately, still had the same issue. I put them back on the correct terminals after, and magically everything was right with the world!
  • Posted 10 Sep 2026 02:59
  • By Austin_B
  • United States
Mitsubishi FD200
Terberg YT182
Hangzhou Maxlion Forklift Imp & Exp Co., Ltd.
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
Mitsubishi FD200
Terberg YT182
