Crown Monobeam forks not going up or down. Stuck in Up position.
Ya, I have a Crown Monobeam forklift that the forks got stuck in the up position and won't go down. What should I be checking?
Model: RMD6026-32
  • Posted 13 Jan 2026 08:45
  • By JBDragon
  • joined 23 Aug'18 - 19 messages
You can check the tilt down/up switches for input in the analyzer. If you see them working, then check the output wiring/components.
Most probable cause is the tilt down switch is failing.
If you confirm the inconsistent switch input, The most economical repair is to replace the thumbwheel harness. It comes with the orange thumbwheel, tilt switches, and wiring to the connector. It's an easy repair.
Get it thru the local dealer. Avoid any aftermarket
  • Posted 23 Jan 2026 04:10
  • Modified 23 Jan 2026 04:19 by poster
  • By Buster_Hymen
  • joined 21 Jan'18 - 16 messages
A few things to check 1- look at wiring to handle and switch 2- check wiring to solenoids 3- check solenoids. im assuming you have no tilt
Since you said lifts and lowers
  • Posted 23 Jan 2026 03:40
  • By John_Bradley
  • joined 10 Aug'22 - 311 messages
Jb69
As I play around with the control handle. I can hear it click when moving the Orange button down. Nothing happens. But I can seem to wiggle it while pushed down just a bit or push harder and get it working. So now I think that is the problem. Not 100% sure.
I think we had a tech fix something on that handle before. I can't recall off hand. It's before out custom software to track repairs on everything including the Forklifts and Pallet jacks. I'm pretty sure something was fixed in this handle by a tech. It wasn't a Crown tech. Crown won't help us. It was a whole huge deal with them. Breakdowns left and right with all of their hardware. Giving us a Forklift that wasn't even freezer hardened like we were told, and switches were getting replaced left and right and failing until replaced by a freezer version, Motor replaced, and so on until it was finally replaced with the forklift we paid for. We can get a Hyster or Toyota tech to work on it. They are not cheap. I may take it apart tomorrow to see if I can find the issue with it.
Anyone have a part number for this?
  • Posted 13 Jan 2026 11:06
  • By JBDragon
Playing around with it again, I got it to go down a few times and then it stopped again. I can hear the Hydraulic pump run when I try going up. Side to side works. Mast going up and down is fine. Going out and in is fine. Everything works just fine except for the forks going down. Even though it worked for a minute just down and then stopped after sitting for hours. I tried turning the forklift off for a minute and trying again and nope, not going down.
  • Posted 13 Jan 2026 10:16
  • By JBDragon
The largest butterfly in the world is the Queen Alexandra's Birdwing (ornithoptera alexandrae), with a wingspan of up to 31cm (just over 12 inches). It is an endangered species only found in Papua New Guinea.
VETTER Forks, Inc.
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Terberg YT223
UN Forklift FD30T-NJM1
