Combilift CB 6000
The number 2 fuse continues to blow when selecting forward. The CB will change into sideways mode and reverse. But when you put the toggle switch into forward mode the number 2 fuses blows. Switched toggle switches and the same result.
  • Posted 1 Apr 2026 07:42
  • By Nic_Olson
  • joined 16 May'25 - 7 messages
Issue was resolved. The short was coming from a damaged wire on the front directional safety light.
  • Posted 8 Apr 2026 05:20
  • By Nic_Olson
Hi transron
Combilift have a dedicated Technical Team covering North America with specific Engineers based in Ontario. If you still need support, you can complete a quick technical support form at the bottom of the main combilift.com web site or direct link https://warranty.combilift.net/technical-support-form/. The form only asks for the minimal info so the team can quickly help you. There is no login required and no charge for this support.
The North America Team will be back to you quickly. Hope you get sorted quickly.
  • Posted 7 Apr 2026 17:48
  • By Richard_Irwin
  • joined 20 Feb'20 - 86 messages
  • Monaghan, Ireland
I have the same issue , won't move in any direction and no back up beeper , i've checked all the fuse's that i can locate , Display shows "PLC" fuse "ST Side" VBB@ 0.02 volts , the othe 5 on dispaly show battery voltage
  • Posted 5 Apr 2026 02:33
  • By transron
  • joined 25 Apr'19 - 4 messages
Hi Nic
Not sure of the specific engine and or age of your truck, but Fuse 2 is linked to the drive solenoid, so you might have a damaged wire. The fuse also covers the Reverse Bleeper and if a Toyota engine has a connected to the Alternator. (You will see all the links in the User namual).
  • Posted 1 Apr 2026 17:32
  • By Richard_Irwin
  • Monaghan, Ireland
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
REPOWERTEK Inc
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
Chandler, United States
Philadephia, PA, United States
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
