Raymond 750 DR32TT:
Code 82 Aux pump runs when truck is cold
I can not find this code in book.
If truck is let sit in freezer aux pump comes on key on code 82.
If truck sits in repair shop worked fine.
Supper cold ambient temp sensor same code 82 and aux pump runs
The customer had unit in freezer over weekend key on burnt out aux pump.
  • Posted 21 Sep 2016 01:14
  • Discussion started by kerbi
So code 82 is a new code for an open in the heated handle.
This is new with update software. If a none heated handle is installed and the heaters are not turned off in the software this code comes on.
I found some units turn heaters and fans on when temp is below 50f
Some units the aux pump may cycle as well.
My next step is to find out why pump stayed on.
Stuck contact ?
  • Posted 23 Sep 2016 00:46
  • Reply by kerbi
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
KION reports dip in Q1 revenue Frankfurt am Main, Germany
