Code 337
Hi,
I have a year 2000 Crown RD-5020 with this code. All the electrical wiring looks good but it will cut out mostly when lifting. If we release the pressure on the hydraulics to drop the forks it will start up again. We replaced the height encoder but it still cut out. We also tried replacing the access 3 module but still not fixed. I'm stuck at where to look next. Any suggestions would help alot. When it does start up it will lift up and down and reach out and in but won't move back and forward and also won't tilt or sideshift.
  • Posted 12 Feb 2026 06:31
  • By Subzero
  • joined 23 Jan'18 - 1 message
code 337 is relating to the temperature of ACCESS 3 is out of range.
Maybe slow air flow in the FAN1 and FAN 2 duct can cause this code so first examine the duct for any restrictions.
  • Posted 15 Feb 2026 02:41
  • Modified 15 Feb 2026 02:54 by poster
  • By mohamed_m
  • joined 16 Jan'15 - 68 messages
  • cairo, Egypt
mmoner1@yahoo.com
I would check over the mast cable
I've had them as they got to bad spot in wire to stop and then when lowered a little it made contact again
Run continuity test on wires
As soon as it cuts out stop and check for continuity
  • Posted 14 Feb 2026 08:52
  • By John_Bradley
  • joined 10 Aug'22 - 294 messages
Jb69
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
VETTER Forks, Inc.
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
