Clark EC500 no longer moves
Since replacing the pump motor for the mast last summer my Clark EC500 has run fantastic. For the winter I've kept it inside a heated garage and on a trickle charger the entire time. When I went to move it out last week it powered up as usual and I backed it out of the garage. Then it stuttered a bit and stopped. The mast and tilt still work just fine. I hear the contact relay engaging in both forward and reverse. I checked the one removeable fuse and it was fine but I think that was the mast pump fuse. I checked the relays and cleaned all the contacts but still nothing.
Does anyone have the trouble shooting guide for this model. I have a feeling its either the faulty accelerator pot or the SCR. I need to isolate the issue so I can get it moving again.
  • Posted 12 May 2026 08:33
  • By Timothy_Sauder
  • joined 7 Aug'25 - 9 messages
Yeah, that's an old General Electric M210 panel. For some reason Clark thought it would work best if they installed it under the battery. I guess dripping acid probably cooled the electrics.
You can find a pretty good guide here: fsip DOT biz/en/content/technical-documents
My Mac said their certificate was bad but it's a safe website. You can also google Flight Systems. From the main FSIP page navigate - resources, technical documents, GE Controllers, M210- M310
The GE guides are pretty good. Also, if this trouble started after a long period of sitting idle, make sure your battery voltage is up and stays up when you try to travel.
Good luck with it.
  • Posted 31 May 2026 00:06
  • By lumberjack
  • joined 27 Jul'07 - 192 messages
  • Maryland, United States
Left side has lift pump and lift pump motor. Right side has electronics. Not pretty though.
  • Posted 30 May 2026 04:24
  • By Timothy_Sauder
Everyone is talking about this being an EV-1 system but that's not what I see in your photo. That card in the middle almost looks like an M210 but I don't see a transformer or capacitor nearby. Have you opened the side panel under the battery? There should be electronics in there. If your fuses are all good you want to be looking at the control panel. A picture of that could probably identify it. (though by the age of those contactors I wouldn't be surprised if it had resistors) If you can identify the control panel there will be repair manuals for anything GE made for this truck.
  • Posted 29 May 2026 11:01
  • By lumberjack
Find 29 wire on card put neg probe to neg on unit put positive on wire 29 at card should have 3.5 -4 volts put unit in neutral and push accelerator the voltage should drop to around 1/2 volt if it does your pot is fine
  • Posted 29 May 2026 03:15
  • By John_Bradley
  • joined 10 Aug'22 - 311 messages
Jb69
To check fuse besides continuity lgrab your meter put negative to negative on unit then put positive on fuse should have battery volts
Then try to drive as the meter hooked to fuse if voltage drops then you have a bad fuse
  • Posted 29 May 2026 03:10
  • By John_Bradley
Jb69
I checked all the fuses and they read ok. I know this is against what Roy said to do but I don't have any replacement fuses handy. My thought it to just jump them for a quick test to see if that is the reason of the failure. Next up would be the trim pot.
  • Posted 29 May 2026 02:45
  • Modified 29 May 2026 02:48 by poster
  • By Timothy_Sauder
This might help
  • Posted 27 May 2026 12:21
  • By John_Bradley
Jb69
Frequently the cause of No Travel with directional contactor closing is an open/blown power fuse. Typically 140amp to 175amp fuse. Do not check the power fuse with a meter, it can fool you. Replace the fuse with a known good fuse and that will verify if that's the problem. If still no travel, proceed to the pot circuit.
EV1 system uses control card input terminal R4 as negative reference point (or you can use battery negative). R5 is wire 29 as pointed out by John Bradley and is the accelerator pot positive input. Be advised, there is also an AGX 0.25amp glass fuse in the pot circuit. This fuse typically doesn't blow but the glue holding the fuse element to the glass case will come loose from driving over rough terrain.
To do a quick check of your scr system, see if you have half battery volts at T2 using negative meter lead on battery negative and positive meter lead on one side of the 1Rec as your test points.
Also note, battery volts means the correct battery voltage, not what you see on the static battery reading. A 36 volt battery that is only at 30 volts after sitting for a long period of time may operate the lift circuit (although at a much lower RPM) but will not operate the EV1 traction circuit.
EV1 control card version 1H3 is a very reliable control card. If you see 5H9, the card itself may be the cause of your problem.
Good Luck Amigo !!
  • Posted 27 May 2026 01:36
  • By RoyOtis
  • joined 28 Jan'11 - 1 message
Since it has been sitting you might check
The drive motor cables also look at wiring from front to back mice have a habit of chewing wires I'm assuming it is EV1 system ? If so you can get diagnostics on internet also each
Position on card and the values
Check wire 29 on card for voltage it should be around 3-3 1/2 volts and drop as accelerated
To about 1/2 volt you don't put it in gear as you test it leave in neutral
  • Posted 14 May 2026 22:15
  • By John_Bradley
Jb69
Venus is the only planet in our solar system that spins in a clockwise direction. One day on Venus is 243 Earth days long, which is even longer than its year, which takes only 225 Earth days.
edition #1302 - 8 October 2026
In this week’s Forkliftaction News , we have two stories reminding us of the power of a generous spirit... Continue reading
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
JLG G12-55A
