BT LWE200 Keypad programming
Good morning
A customer of ours has a number of the above pallet trucks and has asked about reprogramming the keypad to turn the truck on
I assume you need the programmer and the CAN key, anyone have any more details on this please?
Many thanks
Paul
  • Posted 20 Apr 2017 18:10
  • By P_E_G
  • joined 30 Jan'13 - 78 messages
  • Kent, United Kingdom
Hello, Did you ever sort this as I have the same problem, Ive fitted a keypad and the code to turn truck on is 01, I want to change the code but I have no parameter 10 in the parameters.
My trucks a 2012
  • Posted 10 Jun 2026 03:42
  • Modified 10 Jun 2026 03:43 by poster
  • By andrew_k
  • joined 17 Mar'07 - 363 messages
  • England, United Kingdom
The age of the trucks range from 2004 to 2008 by using the CAN key can it be changed using the keypad on the truck or do I still need the programmer?
  • Posted 26 Apr 2017 22:25
  • By P_E_G
Depends on the age of the truck.
Normally a BT CAN key is all thats required to change the pin codes.
You might need to change the login parameter & you may also need the service code to activate the keypad programming mode.
  • Posted 25 Apr 2017 02:53
  • By Forkingabout
  • england, United Kingdom
What do You need exactly?
Did You know how to change Login password?
  • Posted 24 Apr 2017 08:19
  • By Jarun
  • joined 30 Nov'12 - 8 messages
  • 03-144, Poland
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
Taylor TT300
SMV (Konecranes) 33-1200C
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
