Raymond EASI REACH:
Battery drain when using lift
I've got a Raymond EASI R35TT which started having issues with battery drain recently. When you charge the battery, I get a full charge and can drive the unit, side shift it, tilt everything but lift. As soon as I energize the lift feature, the motor bogs down and quits. Shortly after that I get an error code 45.
Also, when the lift grinds to a halt I get a very strong sulphur smell. It only happens when using the lift, otherwise nothing. Anyone seen this one before?
  • Posted 4 Aug 2015 06:52
  • Discussion started by sterback
  • Maryland, United States
RS
Thanks. I think I figured it out. The battery was shorting to the frame. Cleaned it up, eliminated the contact, charged it and it seems to be working fine. Thanks for your help
  • Posted 5 Aug 2015 04:10
  • Reply by sterback
RS
lift takes more amperage than anything else. what is the batteries real state of charge, how much does it drop from "at rest" voltage (at the battery cables) to 3 seconds stall with hydraulic lift at maximum lift height and handle full on.
  • Posted 4 Aug 2015 07:51
  • Reply by edward_t
edition #1229 - 8 May 2025
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
