Backfired now will not start
Hello.
I have a unit that backfired and now will not start.
The unit will crank but no start.
I have changed the LP regulator and spark plugs.
Have checked for spark and all good.
Removed the mixer diaphragm and inspected for rips. None.
Going to removed the timing cover and inspected the belt and marks to make sure nothing has jumped time. The unit has around 3900hrs.
Any suggestions would be great.
  • Posted 3 Feb 2026 06:51
  • By mark75
  • joined 20 Dec'12 - 6 messages
Also check the wiring from key switch to
Ecm as well if it is back firing it could be a loose or bad connection that when it loses connection it's like turning the key off and back on (back in the day we did that in the shop to scare people ) causes a loud backfire
Also rpm sensor and wiring as well as lock off pretty much anything that can cause temporary loss of fuel or ignition
  • Posted 12 Feb 2026 11:18
  • By John_Bradley
  • joined 10 Aug'22 - 303 messages
Jb69
Checked the diaphragm. All looks good.
I found the throttle body was damaged bye the backfire. It cause the butterfly to force close and ripped the teeth of the plastic gears.
So I replaced the throttle body with a new one.
The unit ran for about 30min great and did it again.
Backfired and back to the same issue. Broken gears. Such crap.
The unit has no know fault in the display.
I'm going to replace the throttle body again and connect to the unit with spectrum and see if there any problems in the ecm during the idle up cycle.
Thanks for any help.
  • Posted 12 Feb 2026 02:56
  • By mark75
Check the diaphragm in mixer sometimes when they backfire it blows a hole in it
  • Posted 12 Feb 2026 02:07
  • By John_Bradley
Jb69
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
SNORKEL A46JE
Taylor TX175
New - Sale & Hire
