story with forklift is they were loading a container and it was idling and just Shut off suddenly, After 2 different people & 2 different distributors couldnt figure it out I decided to take on the task,
First i set the #1 piston to TDC, distributor was NOT pointing to #1, pulled the distributor and got it Close to #1, confirmed it has spark, gas is getting into cylinders, but still doesnt seem right. it wont start on LP gas, so i tried non chlorinated brake clean and it WANTS to start but wont actually run.
is it possible for the gear on the camshaft for the distributor move AND if i completely pull the distributor can i turn the ignition timing with a giant screwdriver (obviously i can figure this out easily, just curious before it get into it)
Finally, What do you guys recommend i do in this situation? thank you
