The special advantages are:
SAFETY AND PRODUCTIVITY:
- Advanced AC control system, eliminating the motor brushes, which minimises maintenance requirements. Intelligent regenerative brake system provides strong starting power on ramp up.
- Adjustable driving speed. 4 levels, from 3km to 10km.
- EPS (electric power steering) system with following advantages:
- Steering wheels are automatically reset (up to front position) when the truck is turned on.
- Travelling speed is decreased automatically if the truck swerves, which ensures safety operation.
- Turning angle is shown on the display. - Finger-tip control via joystick: driving speed (4 levels), lifting & lowering speed, opening/closing stabilizer.
- Stabilisers (at specific lifting heights) which can work manually or automatically to enhance stability and safety when stacking cargo.
- Applicable in double pallets function while forks are lifting up.
- Built-in pressure relief valve protects truck from overloading.
- Multi-function display: battery state, working hour meter, fault status, driving speed (4 levels), angel indicator of rear steering wheel, etc.
- Low placed battery offers lower center of gravity and better stability. Battery capacity up to 400Ah.
- Side battery with roll-out system for convenient replacement. The battery top cover provides easy access for filling the battery.
- Damping cushion for low-noise operation.
- Emergency power disconnect.
STRUCTURAL:- Compact truck with "heavy duty" construction.
- Low center of gravity ensures stability.
- Wide view masts with clear visibility.
- Masts are detachable from truck frame and with good interchangeability.
- Low step and sensitive dead-man pedal offers comfortable operation.
- Narrower overhead guard towards front, to reduce the risk of getting "hooked" into something.
- Availability of 360 degree steering offers smallest turning radius of 1800mm.
- Adjustable steering wheel and arm support give driver the most comfortable feeling.
- Drive wheel and balanced wheel are combined together to ensure stability.
SERVICE ABILITY:- The low voltage protection system prolongs battery life.
- CANbus technology reduces wiring complexity and increases reliability and service friendly.
- Improved battery plug system makes it easier to connect/disconnect the battery for charging.
 Multi-function display |
|  Finger-tip joystick and adjustable arm support |
 Manual or automatic stabilizers switch |
|  Stabilizers and Side-way battery |
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email:
ruyi@mail.hz.zj.cn,
sales@liftool.com
Web:
www.xilin.com
Or; Click to view the RUYI ShopFront
