 AR Series Paper Roll Clamp. Click to vie larger image. |
The CeMAT 2011 Exhibition represents a very important step forward for Bolzoni Auramo Group and its continuous effort to find the best answer to any sort of logistics and materials handling demand. This year, it will show a number of developments of great interest to all forklift trucks operators.
Bolzoni Auramo will exhibit some of the most recent and interesting products, including:
- Single Double Pallet Handler DS model
- 360° Rotator RC model
- Fork Positioner FZ model
- Integral Fork Positioner SF-Ri model
- Lift Table low profile "U-shape"
- Lift Table "Ergolift"
- Forks
Among the exhibited range, there are some products which warrant special attention:
Paper roll clamp - Model AR
Efficient paper roll handling with built-in damage prevention is a prime guideline when developing all Bolzoni Auramo paper roll clamps. AR series paper roll clamps are designed and engineered to offer superior visibility, higher rotating speed and to be operator-friendly.
- Rotating paper roll clamp for vertical and horizontal roll handling
- Slim and smooth arm and frame design, optimal visibility and advanced hydraulic operation
- Pivoting arm movement. Short and long arms. Non-split arm for single roll handling. Split arm for 1-2 roll handling.
- 180-degree rotation. Hydraulic cushioning in the vertical end position.
- All hydraulic functions protected with built-in pressure relief valves. All service and maintenance points easily available.
This clamp will be exhibited together with a complete series of options to optimize the clamping force.
- CTX, proven, fully automatic clamping force control system for paper roll clamps.
The system uses optimised, lowest possible clamping force for all handling situations and with all paper grades, minimising the possibility of paper roll out-of-roundness. It uses consolidated technical solutions combined with advanced electronics for controlling and optimizing the clamping operations.
CTX is the most accurate system in all handling conditions for different paper grades.
- 4-STAGE PRESSURE-RELIEF VALVE is the basic option, allowing the manual control of the clamping force.
Between the two options, there is a new product, which is particularly innovative:
- FORCE-MATIC, a new fully mechanical pressure control system applicable to all Bolzoni Auramo paper roll clamps in order to prevent overclamping, causing roll out-of-roundness.
One of the system’s most interesting features is its ability to sense the weight of the load from the hydraulic system in forklift and then calculate the best possible clamping pressure. The valve works basically as a mechanical calculator continuously adjusting the clamping pressure measured in the lifting and tilting cylinders. No electrical connections are required. The valve’s heavy-duty aluminium construction is combined with standard hydraulic components. All of these features decrease the maintenance needed. The system can be calibrated to suit most combinations of lift trucks and Bolzoni Auramo paper roll clamps.
And, thanks to the focus always placed on safe and damage-free handling, Bolzoni Auramo has developed a new Intelligent Clamps which will be presented to the market during
CeMAT Exhibition:
NEW!
Intelligent Carton and Appliances Clamp
i - move model, the new and innovative clamp representing the Bolzoni Auramo solution to the excessive clamping problems.
Designed for safe and damage-free handling, the most common application fields are in the white goods and high-volume carton boxes handling.
- Load volumetric detection through electronic sensors on the clamp and automatic clamping force adjustment through dedicated software and control unit.
- Very rigid frame structure with single piece double "T" profile. Wide visibility window thanks to new vertical plates position at the extremity of the frame. Narrow vertical plates. Superior visibility through the frame grants safe and easy handling operations.
- New aluminium arm design with new high friction rubber lining, special Bolzoni design.
- New check valve for simple and precise arm synchronism, easy fitting, new position in the upper profile shadow granting valve protection and high visibility of the structure.
- New fixing system of the sliding pads to relief stress.
- New self aligning cylinder fixing to avoid breakage.
Bolzoni Auramo has further expanded its range of bale clamps and is now able to offer a complete series of bale clamps for handling pulp and waste paper bales.
At the exhibition booth, customers will find the new Pulp Bale clamp model BA-100-P and Bale Clamp model KS-G .
NEW!
Pulp Bale Clamp – Model BA-100-P
New bale clamp designed for superior visibility and greater net truck capacity in heavy-duty pulp bale handling.
- Steel profile frame with strong "T" profile arm carrier
- Welded profile frame with oilon bearings offering performance advantages an longer lifetime.
- Arms welded to the arm carriers. Colorless arm finish.
- Slim and strong arm design ensure easy knifing and tight stacking. Pivoting left arm grants handling even with varying bale dimensions.
- Side shift valve with built-in pressure relief valve
- Capacity 10000 kg / 800 mm
- Clamping cylinders with flexible mountings for heavy duty handling
- High lifting capacity together with a wide choice of arms configuration and mounting options.
NEW!
Bale clamp - Model KS-G
Suitable for handling pulp bales in the paper industry but also commonly used for cotton, wool, tobacco, fabrics and other similar materials.
Welded directly to the clamp frame, the slim arms knife between baled material stacks.New arm design, welded directly to the clamp frame and with reinforced welded elbow. Slim arms allow easy knifing between bale stacks. Slot in the arm upper position for easy installation on the forklift. Steel ribs on arms.
For more information on the Bolzoni Auramo products, please visit the Bolzoni Auramo stand (Hall 26 / stand K16) or visit our website www.bolzoni-auramo.com, or contact the nearest Bolzoni Auramo representative
Click to view the Bolzoni Auramo ShopFront
