 Click to view the larger image |
Objective: Increase efficiency while decreasing labor costs.
It is the million dollar question for many operation managers. How can we increase our efficiency and decrease our labor costs without spending an abundance of cash flow? By installing a
Turn@bout Maneuverability Adapter to an ordinary pallet truck you will significantly increase productivity, efficiency and safety. The inexpensive
Turn@bout is designed to retro-fit most major pallet trucks and only takes minutes to install. The return on investment starts the moment you have finished installing your
Turn@bout.
Using a Turn@bout assisted pallet truck eliminates wasted effort, time, and money.
The
Turn@bout adapter significantly changes the performance of the existing pallet truck. The space required to turn a manual pallet truck with a fork length of 1150 mm is 2540 mm. When the same truck is equipped with a
Turn@bout the turning radius is decreased to 1540 mm. By equipping a motorized pallet truck with a
Turn@bout the turning radius will decrease from 2980 mm to 1800 mm. Turning an empty pallet truck around a corner often requires several attempts because of the pallet truck’s wide turning radius. The
Turn@bout will increase productivity by decreasing the turning radius required for turning by 72%. The worker operating a pallet truck equipped with a
Turn@bout can turn the pallet truck around in a narrow isle entering a pallet positioned behind them. Without a
Turn@bout they would be forced to exit a narrow isle to turn the truck around and walk back to the pallet. "We finish products for other manufactures. A lot of our products come in 40' and 45' containers. The
Turn@bout® helps us unload quick and easy. It's easy maneuverability make for less work and saves steps. The man hours saved makes the
Turn@bout® a great investment" states Arlan Nordin of PodCo a U.S. based company.
Increase safety to the worker.
A
Turn@bout assisted pallet truck increases the safety to the pallet truck handler. A pallet truck was designed to handle heavy loads as a result they are difficult to maneuver. A pallet truck uses the load bearing wheels as their turning radius. However, when attempting to turn an empty pallet truck the front wheels drag and make it extremely difficult for the worker to turn the truck. They are forced to use their back and shoulders to position the pallet truck. The
Turn@bout eliminates the frustration and extreme wear and tear on the worker. The
Turn@bout raises the front wheels of the truck by 6 mm allowing the truck to turn freely on the spot. The
Turn@bout is an ideal application for tight areas such as semi trailers. Many truck drivers have suffered back injuries as the result of wrestling their pallet truck in order to turn it around in the confined area of a trailer. The cost incurred from a work related back injury is astronomical not only for the injured worker but for the employer as well. Saving time at every stop is an added benefit of using the
Turn@bout in a semi trailer.
Maximize your profits. Don’t lose money on injured workers or lost time.
Increase your warehouse space.
The cost of real estate can be a burden to many companies. The value of every dollar spent on a warehouse should be maximized in every way possible. By using a
Turn@bout assisted pallet truck you will capitalize on every inch of your warehouse. Glen Follett, of Hi-Performance Engineering states that "The
Turn@bout® has helped us maintain our 16,000 sq. ft. warehouse space more efficiently. The use of space is of utmost importance and this product, because of its maneuverability in tight areas allows us more flexibility." Glen was able to reposition his racking closer together by using
Turn@bout assisted pallet trucks. He gained valuable space for a small investment.
Capitalize on your warehouse don’t settle for wasted space.
The answer
The key advantages of using a
Turn@bout assisted pallet truck are: increased maneuverability, tracking, and ability to maximize your warehouse space. By adding a
Turn@bout to your pallet truck you will also increase productivity, efficiency, and safety. The
Turn@bout is the answer to the million dollar question for thousands of operation managers – let it be yours!
Space, health and time saving are money.
Video
Click here to see Turn@bout in action!
Web site in many languages
On our web site
www.turnabout.eu you can find more videos, photos and testimonials from customers using
Turn@bout. To visit our Spanish web site go directly to
www.giralibre.com and for Dutch, French and German visit our dealer Robhold BV at
www.turnabout.biz. There is also a Swedish site,
www.turnabout.se.
Distributors wanted
We are looking for distributors all over the world. Please visit our web site
www.turnabout.eu to apply for dealership for your part of the world. In Europe we have SWEDMACH as our main distributor,
click here to visit their website and order
Turn@bout today.
For more company and product information click to view the Bohena AB ShopFront, or email info@turnabout.se
