Ruyi has launched a new model, CBD20R, with innovations designed for the European market, rivalling world’s most advanced products. It is powerful enough to perform applications and comfortable to be operated.
The special advantages are:
SAFETY AND PRODUCTIVITY:- AC control system eliminating motor brushes and directional contactors, which minimizes maintenance requirements.
- Multi-function display: battery status, hour meter, fault code, etc.
- Side-way battery with roll-out system is very convenient to replace batteries. The top battery cover makes it easy to fill the battery.
- Built-in charger as standard.
- Emergency reversing device.
- The IP67 platform sensor system protects against water and dust.
- Built-in pressure relief valve protects the truck from overloads.
- Braking applied with handle upright and horizontal position.
- Emergency power disconnect.
- Low speed switch in the handle.
- Stepless speed control.
STRUCTURAL:- Parallel motor mounting on vertical drive wheel ensures convenience for inspection and maintenance while also ensuring a small turning radius. The structure of motor is water-proof and dust-proof, which makes the braking and motor more durable and reliable.
- Combined balance wheels and driving system increase steadiness, preventing the truck from being rocked from side to side.
- The balance wheels’ loading capacity can be adjusted according to different situations.
- One-piece heavy gauge steel is formed for maximum strength forks.
SERVICEABILITY:- The whole balance wheel assembly can be removed from the truck to repair and maintain.
- The platform can be removed from the truck easily for replacement or repair.
- Low battery protect setting.
- CANbus technology reduces wiring complexity and increase reliability.
- MOSFET control system and built-in charger
- Industrial battery with lock
- Side-way battery changing system
- Fordable platform with sensor
News
Ruyi will exhibit at the
MOVIMAT 2010, Sao Paulo, from August 3rd - 6th 2010 and
Expo Logisti-K, Buenos Aires, from August 10th - 13th, 2010. Our full range of materials handling products will be on show.
If you plan to attend either the MOVIMAT 2010 (Brazil) or EXPO-LOGISTI-K (Argentina), you are welcome to visit our booths:
MOVIMAT 2010, Sao Paulo - Brazil
Stand No. RUA E, #15
Expo Logisti-K, Buenos Aires – Argentina
August 10th - 13th 2010,
Stand No. # 2150
Mr. Chu Jiang - Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email: ruyi@mail.hz.zj.cn,
sales@liftool.com
Web: www.xilin.com
Click here to view the Ruyi ShopFront
