 Click to enlarge image |
In April 2010, EP engineers will unveil a new electric straddle stacker with the latest AC technology.
Appearance- Ergonomic design, with streamlined appearance and improved user comfort.
- The mast can be easily dismantled, allowing different heights with 2-stage & 3-stage options.
- Button switch available as standard to prevent uncontrolled traveled travel speed or roll-back on ramps when loading and unloading.
- AC drive motor has no brushes, it’s reducing maintenance and labour requirements.
- Hydraulic overload protection valve prevents operators exceeding the unit's rated load-handling capacity.
- Explosion-proof valve installed under lifting hydraulic cylinder, preventing suddent mast collapse if the oil pipe is broken.
- Side-pull design of battery box makes it more convenient and safe to change the battery.
- Adjustable fork and straddle accommodate many kinds of pallet.
Performance & productivity- The innovative AC motor provides more power to maintain high speeds with full loads.
- World-leading top quality hydraulic drive unit automatically adjusts the rate of decline, whether loaded or unloaded, ensuring smooth lifting.
- The latest advance AC controller technology, with regenerated braking and anti-roll back as standard, ensures the best performance in the different states.
- American top quality AMP connectors prevent moisture and contaminants from interrupting truck operation in all environments, plus all the wires and cables are reliably protected and fixed, greatly reducing electrical errors.
Operability- All the operatiosn of lifting and traveling are easily controlled via the button switches in the handle.
Serviceability- One-piece lightweight service access top cover conveniently bolts on and off for easy access to all major and key components, reducing service time.
- One-piece micro switch design, easy to replace.
For more information, please visit
www.ep-ep.com
Click here to view the EP shopfront
