Newsletter #376 (View other news stories)
New system for remote monitoring
Hertfordshire, United Kingdom Wednesday, 3 Sep 2008
 FleetControl Manager from Lamerholm |
A new intuitive system launched by Lamerholm will assist companies operate their fleets safely and productively.
The FleetControl Manager works with forklifts fitted with vehicle-mounted computers (VMC) to provide total fleet management. The system, manufactured by ShockWatch, uses the VMC touchscreen to allow operators access to the forklift, general usage monitoring and real-time impact detection.
Lamerholm says any factory using a fleet of forklifts with VMC can benefit from FleetControl.
"It is useful for fleets that need to be managed in order to reduce damage to the forklifts and surroundings, enables maintenance planning and will monitor drivers for health and safety compliance," says Lamerholm.
FleetControl has been designed for large warehouses and logistics centres to maximise and enhance the existing infrastructure and hardware systems.
The system uses the existing VMC so there is no need for a separate display unit on the truck. It features large on-screen buttons and easy to read text, which means operators do not have to remove safety glasses or gloves to use the system.
The system is easily programmed to use existing company ID systems so only trained and certified personnel can gain access.
Clint Branch, engineering vice president of ShockWatch, says the new system offers equipment location services, general usage monitoring and real-time impact detection and recording.
Fleet managers can select up to 10 parameters to be monitored including speed, weight of load, number of lifts, and running time.
Through the EquipCommand software, FleetControl Manager enables management to set parameters from a central location. Alerts are received when action is required and can be sent directly to a desktop computer or via text message.
Specialist engineers at Lamerholm will be able to advise and train customers on how to use the system or can provide a fully programmed system depending on customer requirements.
CURRENT NEWS
