Email
Password   Forgotten?
Remember me Register
Marketplace
Business Directory
Discussion Forums
Spec-Checker
Industry News
This week's news
Media releases
Fork talk
Industry profiles
Safety first
Cargo chat
Product watch
Your focus
Search news archive
Send your news
Events Calendar
Jobs & Resumes
Photo Galleries
Home | About us | Advertise with us | Tell an associate | Contact us | Site map | Help
Search    Options
Your tools:
NEWS : Full Story
Newsletter #227 (View other news stories)
VNA Warehouse Floor Flatteners – Concrete Grinding Specialists at CeMAT
Thursday, 22 Sep 2005
Flatness is an essential requirement of a floor slab in certain categories of industry. Undoubtedly the most important of these categories is that of aisles in high-density warehouses where fixed-path VNA forklifts operate.
Variations in level across the aisle between the wheel tracks of the truck are magnified in proportion to the height of the racking. But this, calculated from geometrical considerations, forms only part of the potential movement at the top of the mast.
Variations in level, both laterally across the aisle and longitudinally down the aisle, induce dynamic movements in the mast and body of the truck and can cause premature failure of welds and disrupt the performance of electrical components.
Floors with poor flatness also create conditions where there is a risk of collision between the load on the truck, or the carrying head of the truck, and the racking. The majority of such collisions are not statistically recorded, as they cause no loss of human life. It is, however, well known that they frequently occur in all countries where there are high density warehouses with typical clearances between the truck’s mounted load and the racked loads in the order of 100–150mm and these clearances are related to floor flatness. If the value of this clearance is 100mm then the requirement to produce a higher standard of flatness becomes even more important.
Warehouses are designed to give a throughput of a certain number of pallets per hour, or a certain number of order picks per hour. To achieve this, trucks must operate at their peak performance. Trucks will only run at their peak if the floor has the desired flatness. On a floor that fails to meet this standard, controlled grinding should be carried out and the most suitable grinder for carrying out such works is the LASER GRINDER.
The Laser Grinder is a high-tolerance, semi-automatic machine that was specially-developed to quickly and accurately upgrade floor flatness in operational VNA warehouses.
The Laser Grinder
Our unique, purpose-developed floor grinding machine, the "Laser Grinder", is completely adaptable to suit all makes and models of VNA forklift, and can effortlessly achieve the tightest of floor flatness tolerances with ease.
The "Laser Grinder", manufactured and operated by the Concrete Grinding Group of Companies, is the most technologically-advanced concrete floor grinding system in the world. It is very fast, clean and free from airborne dust.
Grinding is carried out using water to totally prevent airborne dust and keep the machine’s diamond cutters cool. The onboard vacuum system channels residual water and swarf to a container at the rear.
This system means there is no need for the warehouse operator to protect stock or racking, as the process is free from air-borne dust and is relatively clean. Grinding can be carried out before, during or after racking has been installed (depending on the type and width of cut required).
While working in one aisle, the remainder of the warehouse can be operated in as normal. The newly-ground aisle can be used immediately on completion.
Grinding can be carried out in a number of formats, to suit wheel spacing of the proposed VNA forklift trucks alone, or the less specific, non-defined requirements of the other warehouse equipment that may use the aisles (ride-on pallet trucks etc).
In the case of a three-wheeled VNA forklift, we will grind for the two outer load wheels and the central drive wheel, producing three cut wheel tracks.
Our three-wheel track grinding method is usually based on three wheel tracks of 300mm wide. Please note that a 300mm cut will only have an active flat path of 240-250mm as the edge of the cutting blades used will round off. The active wheel width must include a tolerance for some side to side movement down the aisle.
To give maximum flexibility of the aisle we can grind the ‘whole width’ of the aisle, providing one single, high tolerance smooth ground path. With the whole aisle width method you have flexibility in the future to use a different type of truck or the use of low level order pickers.
Concrete Grinding Limited is displaying its full compliment of services at CeMAt, Hanover Germany 11th to 15th October 2005. See us at Hall 11 Stand G66.
CONTACT US: Contact Kevin Dare @ Concrete-Grinding
Tel: +44 (0) 1484 600080
Fax: +44 (0) 1484 600095
Email: information@concrete-grinding.com
Web: www.concrete-grinding.com
Discuss Forkliftaction.com News stories in the Discussion Forums!
CURRENT NEWS
News story
1. Jungheinrich: Global demand marginally better
2. E-P opens China’s largest warehouse forklift factory
3. Manitex reports 2009 ups and downs
4. Grupo Laeisz now supports Heli brand
5. Konecranes closes factory, finalises acquisition
6. Autoquip acquires American Lifts
7. Drive pedestrians to forklift operator training
8. Watts Tyres sold to Premia Group
9. Trade show exceeds most expectations
10. Swedish inventor develops versatile forklift
11. LFTS sold to Linde Sterling
12. Briefs
13. Narrow Aisle Flexi adds VNA truck to range
14. Werner Global Logistics opens in Australia
15. NZ port rail link on schedule
16. Improving safety for stevedores
17. Businesses warned of safety scam
18. Supply chain project on cards
19. Brighter outlook for Christmas and beyond
Media release
1. Somerset Capital…Leading the way in the field of industrial equipment financing….Today, Tomorrow, and into the Future
2. TCM New Dealer Announcement - Aurora Lift Truck Service
3. Premia Group Limited acquire Watts Tyre Group
4. Automotive component supplier cuts forklift fleet costs with Flexi
5. Lifetime Contribution Award Presented to Cascade Corporation President
6. Nissan Forklift Corporation Announces its New Vice President of Sales & Marketing
7. Fleetman Consulting Inc. | Representing the Interests of the End User
Text Ad
1. Interesting findings about the effect of online advertising
2. Agents, dealers wanted
Safety First
1. Richard Shore: Have your training risks been properly assessed?
Product Watch
1. APEX 11- New A-Lift, 3 wheels driven multidirectional Forklift truck with travel mast.
2. CBD10A ---Semi Electric pallet Truck from Ningbo Ruyi
3. EquipmentFX- Ever heard of a marketing company with a “pay-for-performance” program?
©Forkliftaction.com
Privacy policy
Related links
Site map
About us
Marketplace | Business Directory | Discussion Forums | Spec-Checker | Industry News | Events Calendar | Jobs & Resumes | Photo Galleries
Forkliftaction.com – PO Box 1439, Milton QLD 4064, Australia
Include and Exclude search categories:
Marketplace
Business Directory
News Stories
Discussion Forums
Spec Checker
Events
Tenders
Jobs and Resumes
