 The new high-speed Toyota forklift. |
Toyota has introduced a new, high-speed version of its four-wheel, 80-volt electric counterbalanced forklift, capable of a top speed of 21kph.
The 7FBMF-S forklifts are available in 2, 2.5 and 3 tonne lifting capacities, with open or closed cabins.
Where long travel distances are required to transport a load, the forklift’s speed advantage comes into play, the company said in a statement.
Transport time between pick up and deposit of loads can be reduced, increasing productivity.
The forklift’s efficiency is also improved when used in conjunction with Toyota’s exclusive side-exit, battery exchange chassis.
Batteries are changed by moving them horizontally on and off the forklift, enabling a fast change over with the operator having continual use of the machine.
Toyota Industrial Equipment Europe product manager Craig Walby said: "The side-exit, battery exchange chassis, combined with the different systems available to unload and load the battery, means the truck is highly effective for intensive, long distance movement applications and multi-shift operations."
CURRENT NEWS
