Combilift Australia to exhibit unique handling solutions at CeMAT Australia
- 26 Mar 2015 ( #711 )
Customised handling solutions is not just Combilift Australias' slogan, it's our ethos. Combilift Australia have become known as the go-to company for material handling solutions. At Combilift Australia we believe in providing the customer with the best handling solution available to them. Combilift Australias' passionate and innovative staff work closely with each customer top solve their handling needs.
Combilift is designed to handle long loads safely. By eliminating the need to travel with long loads lifted high, the units provide greater stability. The integrated platform with lower centre of gravity also provides a more stable base.
Using patented, leading edge technology, Combilift forklifts are equipped with a unique 4-way steering system that allows the units to travel sideways with long loads. This system gives
the
operator multi-directional capability.
The Combilift eliminates the unnecessary multiple handling of goods by being able to manoeuvre easily through doorways that are narrower than the load it carries. This results in less product damage, safer handling as well as eliminating the need for oversized doorways or conveyors.
Combilift operates equally efficiently both indoors and outdoors including semi rough terrain. With models to cater for the smallest of loads up to 25000kgs, Combilift Multi Directional Forkilifts can suit even the most difficult application.
To assist your requirements, Combilift will provide you with a free warehouse design/ evaluation with no obligation. A specialised Combilift warehouse consultant will complete a free onsite survey to ensure you get the best solution for your materials handling requirements. Combilift's team of design engineers will analyse your requirements and supply you with free plans, enabling you to make the most of your available space.
Combilift has further customised its fleet with the introduction of the Combilift Straddle Carrier. Designed to handle loads up to 80,000kg, the Combilift Straddle Carrier is not only ideal for handling containers but also oversized loads.Combilift has provided solutions within the concrete, steel, oil and gas, grain, mining industries to name a few. The Combilift Straddle Carrier is the most manoeuvrable in its class. With a turning radius of 7 metres it can work quickly and efficiently in tight areas and with its broad range of lifting capacities will suit almost any application.
For container movements the Combilift Straddle Carrier can be fitted with a top lift spreader attachment. This attachment can handle containers between 20' and 45' without the need to leave the air conditioned driver cabin. Most importantly it can safely deliver a 20 container per hour throughput, making it the most productive unit in its class. With 360 degree driver visibility when carrying loads, the Combilift Straddle Carrier is very safe and easy to use.
Combilift Australia prides itself with its service and support with our whole focus to meet the expectations of our customers in after sales. With our own technicians and comprehensive dealer network across Australia to support your needs we can deliver the level of after sales service you would come to expect from a premium brand. We are fully stocked on spare parts and are able to provide prompt support as required. We aim to eliminate your down time in times of need and our whole aim is to be able to use every customer of our as a referral.
With an office and service facility located in each mainland state we can deliver. Should you wish to know more about what Combilift can offer we would love to hear from you.
We are attending the CeMAT Australia Expo (stand E10) where we will have a comprehensive display of our product range as well as a Combilift representative from each state that can personally assist with your needs. We can also be contacted via the below details:
Please contact:
Combilift - Paul Horsnell
t: 1300 552 422
e: send an email
w: www.combilift.com.au
September 23-25, 2025 - SÃO PAULO, Brazil
October 15-16, 2025 - Las Vegas, United States
November 25-26, 2025 - Singapore, Singapore
