EMC Forklift Parts offer the most informative and comprehensive parts catalogue for Japanese 1.5 to 3 tonne capacity forklifts in the south pacific region.
With over 25 years experience in spare parts, EMC designs, manufactures and distributes quality replacement parts and accessories for the Southeast Asian region.
Located at the doorstep of Asia's large manufacturing network, EMC works with quality manufacturers to offer the most cost-effective replacement products for your forklift needs.
The new "Edition 5" EMC Forklift Parts catalogue has a comprehensive range of parts for Nissan, Toyota, Komatsu, Mitsubishi, TCM, Crown, Hyster and Yale forklifts. Each catalogue item includes an image of the product with its description, make, model and technical information.
The catalogue is indexed into 12 sections:
Accessories - Warning lights, alarms, horns, work lights, indicator lamps, globes, mirrors, gauges, seats, wheel knobs, hydraulic jacks.
Electrical & Battery Electric – SCR components, switches, solenoids, contacts, contact kits, contactors, battery connectors, fuses, carbon brushes, poly wheels, steer, drive, brake, hydraulic, mast.
Engine - Engine components, oil filters, air filters, ring gears, starter motors, alternators, ignition parts, pressure switches.
Fuel - LPG components, fuel pumps, fuel filters, accelerator cables, accelerator pedals.
Cooling - Water pumps, radiator hoses, thermostats, radiator caps, temperature senders, fan belts, fans.
Transmission - Plates, transmission kits, torque converter kits, valve kits, transmission filters, temperature sender, neutral start switch, reverse switch.
Drive - Studs and nuts, seals, wheel bearings, rims.
Brake - Master cylinders, wheel cylinders, brake shoes, brake drums, brake components, brake cables, pedal pads, brake switch.
Steer - Tie rod ends, steer link pins and bushes, knuckles, bell cranks, hubs, king pin kits, centre pin kits, pivot bushes, seals, wheel bearings, hub bolts and nuts, rims, steer cylinder kits.
Hydraulic - Hydraulic pumps, hydraulic filters.
Mast - Tilt cylinder seal kits, tilt pins and bushes, lift cylinder seal kits, mast bearings, mast pulley kits, mast bushes, wear strips and shims.
Forks - Sideshift components, fork pin kits, forks.
For your copy of the new EMC catalogue email
info@emcgateway.com or log onto
www.emcgateway.com.
