AUSA RT Forklift takes the lead
- 21 Nov 2013 ( #643 )
C 350 H in construction work - Click for larger view
Mainly in activities such as building construction, wood, orchard, recycling and mining, the AUSA forklift offers a great profitability thanks to its exclusive design and great advantages with respect the pure industrial forklifts. Its models C 150 H, C 250 H, C 350 H and C 500 H are leaders in their respective segments of 1'5, 2'5, 3'5 and 5 ton load capacities. They offer to the customer a great variety of customization to adapt the forklift to specific customer needs.
AUSA forklift is the best solution for handling materials in outdoor zones when the space is reduced, the ground is irregular and
C 500 H in quarrying - Click for larger view
when occasionally, the forklift
has to work in indoor areas thanks to its great compactness. The main differential advantages are:
  • Exclusive compact chassis design in combination with a balanced weight distribution providing maximum flotation on the ground.
  • High efficiency "Automotive" hydrostatic transmission Bosch-Rexroth that permit maximum agility to move materials with safety and quickness.
  • Clean, silent, and minimum consumption Kubota engines
  • High ground clearance chassis in combination with large and width tyres for obtaining maximum traction and flotation on the ground and the best load stability on forks to avoid the falling of loads.
  • High visibility and comfortable folding cabin that offers maximum drive control and quick access for periodic maintenance.
  • Exclusive 2wd/4wd FullGrip®System. The FullGrip® System allows selectable 4WD by means joystick push-button when you need. In most all terrain situations this is all that would be required to cross a boggy section or to pull out of a hole.
AUSA designs and manufacturers forklifts since 1972 and sell them in more than 100 countries around the world by means a network of 500 dealers. AUSA is the few forklift manufacturers that exports to competitive Japanese market.
C 150 H in farming task - Click for larger view
C 250 H in wood industry - Click for larger view
AUSA is located in Barcelona-Spain and is leader in compact industrial vehicles in the segment of site-dumpers, RT Forklifts, telehandlers, street sweepers and tool-carrier municipal vehicles.
For more details on the AUSA RT Forklift Range call to +34 93 874 73 11 o contact to Send an email or www.ausa.com.
AUSA Center, S.L.U.
E-mail: send us an email
Web: www.ausa.com
Tel: (+34) 93 874 73 11
Fax: (+34) 93 873 61 39
Apartado de Correos 194
08243 MANRESA
