EP is dedicated to meeting the needs of customers worldwide with products that deliver superior value. The new EP Counterbalanced Electric Stacker features AC technology in a compact and flexible design that is as easy to operate as it is to maintain. The new truck has the ability to handle loads just like a sit-down rider truck, but at a lower purchase price and with significantly lower operating costs. Managers will appreciate the unit’s ability to perform well in support roles, indoor or outdoor applications – including dock work, and for general purpose material handling.
The EP Counterbalanced Electric Stacker features:
Performance and reliability- An innovative AC drive system with quick response, accurate control, impact protection, and excellent power efficiency.
- Advanced regenerative braking that reduces energy consumption and extends the vehicle’s duty cycle per charge.
- A best in class hydraulic power pack that automatically adjusts to the rate of vertical travel whether loaded or unloaded to ensure smooth lifting, low noise and minimal vibration.
- Compact chassis and low mounted tiller provide both a tight minimum turn radius and easy steering effort.
- Large center mounted tilt cylinder ensures smooth mast action and excellent load handling control.
- Counterbalanced design accommodates a wide range of load sizes.
Safety- Emergency power disconnect within easy reach of operators.
- Extra wide front wheel stance improves stability while angled heavy gauge steel housings protect wheels from damage.
- Emergency check valve prevents the mast from collapsing in the case of hydraulic failure.
- Long tiller handle keeps operators away from the chassis during transit.
Productivity & Efficiency- Side loaded battery compartment for quick & easy battery replacement.
- Two and three stage mast options satisfy different lift and lowered height demands to fit the unique requirements of an application.
- Electric power steering and platform options allow for additional operating capabilities reduce strain on operators.
Serviceability- Quality American AMP connectors prevent moisture and contaminants from interrupting truck operation in all environments. In addition, all the wires and cables are well protected and marked to prevent system issues and reduce maintenance time.
- Anti-roll back device keeps the truck from rolling backwards on ramps or inclines allowing maintenance on uneven surfaces.
- Main electrical components can be accessed without the need of tools.
EP Equipment is a world leader in the manufacturer of materials handling equipment and associated components.
EP has built a worldwide sales network in more than 40 countries across the globe with associate companies in the United States, Europe, Canada, Japan and Korea. In 2008 DHF Intralogistik ranked
EP the 24th largest materials handling manufacturer in the world, and
EP has continued to grow by over 50% per annum ever since.
EP is engaged in an ongoing effort to expand, innovate, and deliver exceptional material handling products and solutions. Let’s grow together.
Contact details:
EP EQUIPMENT CO., LTD.
TEL: 86-571-28035657/28035633
FAX: 86-571-28035665
EMAIL: info@ep-ep.com
Click here to visit our shopfront
