Ever been given the challenge from a customer to find a really compact, quality manufactured and reliable electric forklift truck?
Look no further as we here at
European Handling have been appointed the
Sole UK distributor for V. Mariotti , Italy. Mariotti have been building small forklifts since 1920 and have always had a hold in the European market place for what they make, however the UK was a difficult market to crack, so knowing that we already had a comprehensive market with our other products they appointed us to help create a UK market for small fork lift trucks!!
Models start from 400Kg and max out at a whopping 1300Kg.....and with max lift heights of 5700mm these trucks can be used in places others would not dare sqeeze into.
V.MARIOTTI products range can go where no other forklift trucks can go thanks to unique L2 and Ast3. And manoeuvrability can be improved by a lot of possible customisations:
- Special masts in order to reduce the h1 or the h3
- Modification of the overheadguard in order to reduce the h5 (even overheadguard removal, allowed till 1800 mm lifting height)
- Conception of customised accessories: rams, forks, clamps.
And products size is not the only asset! Did I talk to you about our PA option?
A wider front axle allows a better weight distribution of the machine on the floor. This can be helpful when it is needed to drive into an elevator and to go to the upper floors. PA option is available in all the ME AC range.
Last but not least, our company is able to offer a lot of special fittings such as expolsion proof, cold storage (-25°C), drive-in, painting on demand, etc…
So if you have that challenge, call
Andy Williams on 07970 129095 and let us share your size problem...
Or click here to get the brochure
| ____________________________________ |
Did you know that European Handling Equipment can offer you details on Bespoke Handling Solutions. Whether it's a special lift height on a pedestrian stacker or a 15000Kg Burden Carrier as pictured here we have the ability to design, test and manufacture to client requirements.
European Handling Equipment Ltd
t: 0044 1384 423330
e: andy@european-handling.com
w: www.europeanhandling.com
