Operators overloading their forklifts?
Creating unsafe and potentially deadly situations?
Want accountability for abusive operators?
KEYTROLLER has several solutions for overload sensing
WEIGH-ALERT---Overload warning system
- Hydraulic sensor is installed in pressure side below mast.
- Indicator constantly monitors weight being lifted and sounds audible alarm before the maximum lifting weight is reached.
- It displays the load as a % of the maximum load capacity.
- When weight reaches 90% of maximum capacity, device sounds 5 beeps and the display begins flashing.
- When load reaches maximum capacity, device internal alarm (and optional external alarm where fitted) will sounds continuously until the load is reduced.
- Optional 3 LED light bar (clear, amber, red) is mounted at eye level for clear warning.
- The instrument memorizes the number of times it is overloaded along with maximum overload as a % of the alarm load.
- Overload info is viewed on display by management.
WEIGHTROLLER—Hydraulic scale with overload warning.- This model has all the same overload features and capabilities
Also can be set to show load weights in Kgs or Lbs.- "ON" mode: The weight is sampled constantly, and so the displayed weight is a ‘live’ figure that changes accordingly.
- "AUTO" mode: Unless the calculated weight changes by more than 2% over a set weight sampling period (1 sec), the displayed weight is frozen.
- In ‘auto’ mode, the calculations for Percentage Load indications and Overload alarm functions remain based on constant ‘live’ weight sampling.
SMARTIE---Drive camera----VIDEO PROOF OF OVERLOAD- Up to 4 SMARTIE cameras installed on forklift.
- "Cigarette pack" sized DVR with SD card, mounted in lockable enclosure.
- Hydraulic sensor is calibrated to 90—100% of full lift capacity, has output at overload threshold.
- Overload sensor is connected to DVR trigger input, when sensor outputs signal-- video is started and recorded to SD card.
- Management removes SD card from lockable box to review saved impact events.
- SD card inserted into card reader in PC, software is on SD card.
- Management can evaluate video overload event simultaneously from 1-2-3 or 4 camera views.
- Events can be saved as AVI file in drivers file.
KEYTROLLER-- access monitoring system with overload sensing - Color LCD display with built in RFID reader and WiFi radio.
- Checklist automation, impact and speed sending.
- Optional hydraulic sensor calibrated to 90—100% of maximum lift capacity.
- Overload warning shows on LCD display.
- Programmable "grace period" and shut down.
- Event is recorded into device memory
For more information view website: www.keytroller.com or contact KEYTROLLER, LLC. 813-877-4500 or email: info@keytroller.com
