 Click to enlarge image |
RUYI Model CBD 20K(D), features a new design, very competitive pricing, and a range of different options..
Advantages:
SAFETY AND PRODUCTIVITY:
- Advanced AC control system eliminates the motor brushes and directional contactors, which reduces maintenance requirements. Intelligentised regenerative brake system increases overall truck performance by decreasing battery charge intervals.
- Side-mounted battery with roll-out system makes for convenient battery replacement.
- Emergency reversing device.
- Built-in pressure relief valve protects the truck from overloads.
- Long handle tube for flexible and labour-saving operation.
- Emergency power disconnect.
- Low-speed switch on the handle.
- Stepless speed control
STRUCTURAL:
- Parallel-mounted drive wheel produces a small turning radius with easy maintenance. The structure is waterproof and dust-proof.
- The riser axle located at the highest point of forks, protecting the riser axles from constant contact from uneven floors. Pull rod design protects the rod from bending.
- Spring-loaded castors improve lateral stability on uneven floors and enhance truck performance and service life.
- One-piece heavy-gauge steel is formed for maximum strength forks.
SERVICEBILITY:
- Low battery protection setting prolongs the battery use time.
- CANbus technology reduces wiring complexity and increases reliability.
- Hall-effect throttle control eliminates component wear and requires no mechanical adjustment.
- All pivot points have grease fitting and serviceable bushing, reducing component wear and extending component life.
RUYI Electric Pallet Truck with Scale Model: CBD20K(C) for option: Click to enlarge image |
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email:
ruyi@mail.hz.zj.cn,
sales@liftool.com
Web:
www.xilin.com
Or; Click to view the RUYI ShopFront
