 Model: CQD12W |
RUYI pedestrian-type counterbalanced electric stacker features wide front visibility, low centre of gravity, small turning radius, good performance, easy operation and low noise. It is the ideal option for materials handling and goods stacking in
narrow-aisle warehouses.
Advantages:
STRUCTURAL:
- Long handle structure makes its steering light and flexible.
- Two lifting cylinders placed on the outsides of the mast improve the lateral stability and widen operator visibility.
- Germany-imported special steel mast.
- Vertical driving wheel with high driving efficiency and low noise, easy installation and maintenance.
- The truck has a compact structure and low centre of gravity which provides good steering stability.
- Absence of side plate on both side of battery box encourages heat dissipation and eases service.
SAFETY AND EFFICIENCY
- AC frequency conversion traction motor: compact structure, good performance,
 Model: CPD15W |
regenerative braking and easy maintenance. - The forks’ tilting system eases loading and stacking.
- The min. turning radius is 1,560cm, ideal for narrow spaces.
- High storage battery ensures strong and long-lasting power.
- With BDI w/interrupt, prolongs the battery’s use time.
- The braking system combines brake and regenerative brake, greatly prolonging the life of friction plate.
- An emergency stop switch and electricity lock button, and multi-valve controlling levers provide for ergonomic operation.
- The adjustable regulator valve can adjust the lowing speed of the masts.
EASY MAINTENANCE
- Uses magnet force for battery cover closing instead of screws, for convenient installation and maintenance.
- AC control system with sensitive response, low noise, less maintenance and accurate control of speed.
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email:
ruyi@mail.hz.zj.cn,
sales@liftool.com
Web:
www.xilin.com
Or; Click to view the RUYI ShopFront
