 BT80: 80,000 lbs, cap @ 24" Load Center. Click to view the larger image |
HMS LIFT Inc. pioneered the development of these specialized material handling machines and with over 45 years of experience HMS knows how to build the right product.
Each
BRUTE LIFT® manufactured by
HMS Lift Inc. is designed and built by craftsmen to meet custom lifting specifications.
OPTIONAL EQUIPMENT- GM LPG or Cummins Diesel Tier III certified engines
- Coil Prongs
- Side Shift
- Fork Positioners
- Quick Disconnect Carriage
- Booms - 30,000 - 120,000 lb capacity - Engineered & Certified
 BT140-24HD - 140,000 lb. cap @ 24" Load Center. Click to view the larger image |
These
Brute Lift® trucks come in a range from 40,000 to 200,000 lb. capacity. Trucks can be custom ordered to fit exact lifting and handling needs.
Different style cabs, various fork sizes, tire sizes, overall dimensions, lifting heights, lifting capacity, all can be modified to suit your specific needs. Units can be fitted with optional equipment such as booms, coil prongs, side shift, fork positioners, etc. All
Brute Lift® Heavy Lifting Equipment is fully inspected and put through rigorous testing to ensure it meets or exceeds the respective load rating before delivery.
 BT120-24HD - 120,000 lb. cap @ 24" Load Center. Click to view the larger image |
Most units come with a choice of engine, Tier III certified GM LPG engine or Tier III certified Cummins diesel engine, either engine at no extra cost.
Each Brute Lift unit comes with a 6 month "carriage to tow hook" warranty and a 6 month powertrain warranty.
HMS Lift also carries an inventory of used large capacity lift trucks.
OUR GOAL-To supply the BEST
DEALER INQUIRIES INVITED!
HMS LIFT Inc.
Tel: +1 519-448-1055
Email:
sales@hmslift.ca
Web:
www.brutelift.com
For more company and product information visit the HMS Lift ShopFront.
