RUYI's new Electric High Lever Order Picker with lots of advantages.
- Low centre of gravity ensures good stability.
- Advanced electric steering technology (EPS) with ergonomic design, automatic reset, height display and automatic deceleration on high lifting.
- Fingertip control via joystick, stepless speed control for driving, adjustable lifting and lowering speed.
- Buffer oil cylinder: the oil cylinder will automatically decelerate when raised 500mm off the ground to prevent impact and reduce noise.
- The mast and the frame are dividable and exchangeable.
- Low battery protection setting prolongs the battery use time.
- AC motor eliminates replacement of the carbon brush, provides good ramp starting performance and regenerative braking functions.
- Sideway battery is convenient for exchanging and maintaining.
- The mast material is a special type imported from Germany.
- The truck can automatically decelerate when turning quickly.
- High performance multi-function instruments with LED light and display function. LED indicators include battery activity, fault indicator, Electric thermometer indicator, pedal indicator and handbrake indictor.
- Multi-function display, include battery status, performance, working hour, accelerator, speed, wheel position and travel direction.
- Press right and left keys to switch to different grades: high, normal, low and lowest.
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email:
ruyi@mail.hz.zj.cn,
sales@liftool.com
Web:
www.xilin.com
Or; Click to view the RUYI ShopFront
