 Click for larger image |
Lencrow has just taken delivery of two new
C500H 4wd Ausa rough terrain forklifts. These units are fitted with the new
Full Grip selectable 4wd transmission. The Full Grip system is engaged with the push of button located on the multi purpose joy stick and is only used as required. This system reduces tyre wear up to 50% on hard surfaces and improves the maneuverability of the unit. The units are power by a Kubota 63kw engine.
The units delivered are fitted with a fully enclosed cabin with Ausa designed cabin with little loss in visibility. The cabin comes with factory cooling and heating the package is complete with suspension seat offering the operator safe and comfortable working environment.
The
Ausa C500 is compact for a all terrain unit of this capacity being 2000mm wide and 3450mmlong to the face of the tynes. Still it is designed for off road with 280mm of ground clearance and 18-19.5 tyres on the front and 10.0/75 -15.3 on the rear.
Ausa units come with full road lighting as well as amber rotating beacon and reversing alarm. Other OH&S points worth noting is they comply to the braking system required in mine applications today with spring apply brakes in the event of the units engine stopping the brakes will come on.
Rod Jackson of Lencrow says "The new model is a vast improvement on our previous units the drive is smoother and the unit steering is more direct with better lock. The air conditioning works very well, cooling the cabin in minutes after we left it in the sun for two hours."
For more details on the C500H or any Ausa equipment contact Lencrow on 1300 536 276
Lencrow Materials Handling
Phone: 1300 536 276
Web: www.Lencrow.com.au
Email: Sales@lencrow.com.au
For more product and company information Lencrow ShopFront
