Click for larger image. |
Ruyi launched new type Full Electric Pallet Truck with innovative design in Model CBD 20R, which is heavy duty type with capacity 2000kg-2500kg. It is powerful to perform applications and comfortable operation.
Good safety and efficiency- Power steering system (EPS) for easier steering operation, flexibility and enhanced safely.
- Multi-function display: battery status, hour meter, fault code, slow running state, etc.
- High-capacity battery(240Ah)and high-power Drive Motor provide added power and ensure longer runtime.
EPS system and Intergal Electric parts. Click for larger image. |
- The control system uses efficient micro-computer MOS, AC adjustable-speed drivemotor provides long life and good speed adjustment performance, and is maintenance-free.
- AC-motor eliminates carbon brushes and has good starting performance on ramps.
- The side door of battery is easily opened. Once the locking mechanism is loosened, it is very easy to pull the battery unit out from the side.
- Tiller heads are imported from Germany which provides safer operation.
- Built-in pressure relief valve protects the truck from overloads, and increases the truck’s reliability.
- Braking is applied with upright and horizontal handle positions, increasing the truck’s safety.
- Emergency power disconnector.
- Turtle-shaped low speed switch.
- Stepless speed control.
Structural:- Standing drive motor system makes the replacement and maintenance of the driving wheels easy and convenient.
- Combined balance wheels increase steadiness, preventing the truck from rocking from side to side.
- The balance wheel is detachable, and is convenient to maintain.
Easy maintenance- Low battery protection setting prolongs the battery use time.
- CANbus technology reduces wiring complexity, making the line clear, orderly and easy to repair. And also increases the truck’s reliability.
- Hall-effect throttle control eliminates component wear and prolongs its use time.
- With reasonable design, the cover is reliable and easy to dismantle, which makes the maintenance of the electrical parts very easy.
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email:
ruyi@mail.hz.zj.cn,
sales@liftool.com
Web:
www.xilin.com
Or; Click to view the RUYI ShopFront
