Ningbo Ruyi is proud to introduce a new electric stacker: the CDDK series. It has features as follows:
Safety and productivity:- AC Motor eliminates replacement of carbon brush.
- Multi-function display: battery power, fault code, hour meter and speed;
- The side gate and the battery cover are openable. Battery can be removed from the side, making it very convenient to replace and maintain batteries.
- Damping cushion for low-noise operation;
- Emergency reversing device in the handle provides improved operating safety.
- Auto-deceleration function makes operation safer.
- Built-in pressure relief valve protects the trucks from overloads, increases the reliability.
- Braking applied with handle upright and horizontal position, increasing the safety of the truck.
- Emergency power disconnect switch.
- Turtle-shaped low speed switch.Stepless speed control.
Optimum structural design: - Low center of gravity ensures the stable operation.
- Vertical drive wheel ensures convenience for maintenance while also ensuring a small turning radius. The structure of motor is water-proof and dust-proof, which makes the braking and motor more durable and reliable.
- The mast and the frame are dividable and exchangeable.
- Full free lifting, fit for working in confined areas. (The lifting height is 3 meters, can enter into a 2-meter height door);
- Firm imported mast.
Serviceability:- Low battery protection setting prolongs the battery use.
- The electronic components’ concentrated design simplify the circuit and makes easy access to assemble, debug and maintain,
- CANbus technology reduces wiring complexity and increase reliability.
- Hall element reduces wear components, resulting in increased component life.
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email:
ruyi@mail.hz.zj.cn,
sales@liftool.com
Web:
www.xilin.com
Or; Click to view the RUYI ShopFront
