Electric Forklift Trucks from Ningbo Ruyi
- 23 Sep 2010 ( #480 )
Ningbo Ruyi FB20AC series has been extended with a NEW type of electric forklift with AC power, designed to advanced international standards, with streamlined design and easy to operate, superior ergonomics and advanced dependability, safety and durability, enhanced productivity and lower operational costs. This is really the safest, most comfortable, and most efficient choice.
This time, we'd like to introduce a new model - FB20AC-III:
  • Driving compartment: Designed according to the SIP point the compartment features great comfort for fatigue-free operating.
  • AC driving motor; AC lifting motor;
  • Double controllers and double motors
  • Stepless speed regulation for traction and lifting. Delay time function for tilting safety.
  • Mast cylinder lowering with buffering system, shock absorber steering Axle for reduced noise. All seal kits imported from Japan (NOK), transmission and working system have low noise.
  • The climbing performance is superior to competitor products around the world.
  • Regenerative braking in reversing mode and regular brake pedal use reduces operator effort and improve the brake life.
  • The optional of a third safety pedal allows the driver to reduce the driving speed while stacking and/or steering operations. (Press both accelerator and third safety pedal at same time.)
  • Multifunction LCD/digital display: with digital service hour meter (actual or cyclic duration factor), battery discharge indicator, clock, error code and warning displays. Provides fast and accurate monitoring of truck status.
  • Double sealed electric connectors provide a water-proof connection and are sealed to prevent contamination.
  • Electrical interlock with seat switch prevents the truck from moving forward if the battery cover lock is not applied; and stops the cover opening in the event of the truck tipping over.
  • Adjustable tilt steering column. Steering wheel can be adjusted for the most comfortable operator position.
If you are interested in this item or other products, or if you have any questions, please feel free to contact us:
Contact Person: Mr. Chu Jiang
TEL: 86-571-87153626, 87153634
FAX: 86-571-87153628, 87153638
Email: ruyi@mail.hz.zj.cn or sales@liftool.com
Web: www.xilin.com
Click here to view the Ningbo Ruyi Shopfront
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
