HYTSU Product Range
- 21 Jan 2010 ( #445 )
S100 Series 1.5-5t Gasoline Powered (LPG) Forklift
Responding to the suggestion from customers, HYTSU Group began to research small capacity ( 1.5ton and 1.8ton ) and large capacity( 4-5ton ) of gasoline powered forklifts。After entering the market in second half of 2009, the small ton gasoline forklifts have earned high appreciation. And in 2010, we will promote the big capacity forklifts which are manufactured using brand-new technology:
  • Advanced technology and high quality manufacturing make it more comfortable and easy to operate.
  • Easy-open hood ensures a good heat insulation, noise absorption and shock absorption. This means easier operation and maintenance.
  • All the trucks comply with strict environment protection rules, and each forklift truck is equipped with overhead dual air filters; NISSAN, MITSUBISHI, IMPCO, etc. high quality engines and components.
  • Advanced heat dissipation technology and cooling system enhance the radiating capacity and increase the work capacity.
  • Automatic adjusting clutch systems improve gear shifting.
  • Overhead dual air filters and buffer device for transverse steering axle
  • LPG option offered.
FC25
FC25
S100 Series 2-3t Cushion Tyre Forklift
  • Engine Power: Gasoline/LPG
  • This forklift truck is designed to lift and transport materials in such industries as food, pharmaceutical, electronics and instrument, etc.
  • Widely used in warehouses and containers, this model is noted for its small size, small turning radius, lower gravity and good mobility.
  • When equipped with a high mast, the lifting capacity is usually bigger than a forklift with the same capacity. This makes it more efficient.
FE18S
FE18S
S100 Series 1.2-2t three-wheel Electric Forklift
This 3-wheel Electric Forklift adopts 100% AC power as well as more advanced features:
  • The front driving tyres with double motor which are two high-performance, low-noise, 3-way AC motors.
  • The power management keeps the performance of forklift and accumulator balanced in any conditions of operation, with optimal electric supply status.
  • Ability to load and unload the accumulator with a hand pallet truck, electric pallet truck or forklift truck, saving labour and boosting safety by avoiding swinging and danger in transiting.
  • 3 mode power management with SME electronic controller.
    1. Economic mode: limited performance of forklift.
    2. Standard mode: balanced performance of accumulator and forklift
    3. Qualified mode for maximum performance
FE25SF
FE25SF
S100 Series 1.6-2.5t four-wheel Electric Forklift
This brand new 4-wheel Electric Forklift uses 100% AC power and boasts the following advanced features:
  • The front driving tyres with double high performance, low noise, 3-way AC motors.
  • Power management guarantees optimal electric supply status in all operating conditions to balance performance and power consumption.
  • Bolzoni Side shift and multifunction assembled instrument.
  • 3-mode power management with SME electronic controller.
    1. Economic mode for longer operation
    2. Standard mode balances performance and power usage
    3. Qualified mode for maximum performance.
D25
D25
S100 Series 2-7t Diesel Powered Forklift
  • The lifting system chain and the cylinder are equipped separately, providing wider visibility and improving operator safety.
  • Integral dual air spring supported hood and hook type plate improves heat insulation, noise absorption and shock absorption. This allows easier operation and maintenance.
  • With an improved hydraulic tubes design, faster lifting is achieved. Automatically adjusting clutch systems improve the gear shifting.
  • Advanced engine and heat dissipation technology makes it more stable at work.
  • Floating hood and buffer device for transverse steering axle improves hock and noise absorbing and driver comfort.
SL4095
SL4095
Self-elevator stacker
The SL4095 travels with your Van, Pick-up or Trailer. One SL4095 can replace your Tail-lift, Hand Pallet Truck, Stacker, Ramp and Swing lift. The SL4095 is capable of easily moving, loading and unloading palletised goods of up to 600kg. The SL4095 is easy and quick to transport, in your vehicle, along with the load so that there will be no unloading or reloading at your destination.
Independently powered by its own 12V electro-hydraulic power pack, the ability of the SL4095 to load itself into a van, pick-up or onto a trailer (with or without a load on the forks) is what makes the SL4095 so unique. An innovation that revolutionises the field of load transportation with Light Commercial Vehicles.
Contact Info
Phone: +86 021 5869 0003
Fax: +86 021 5869 2793
Contact Person: Li HuiYing
Email: info@hytsu.com
Website: www.hytsu.com
Address: No.1 Jilong Road, Waigaoqiao Free Trade Zone, Shanghai. 200131 P. R. China
Click here to view the Hytsu Shopfront.
