Bolzoni Auramo Launches A New Fork Positioner Series
- 3 Sep 2009 ( #426 )
Bolzoni Auramo has introduced a new range of heavy-duty sideshifting fork positioners with bar-mounted forks, suitable for a wide range of pallet and load handling applications. The product is available in two versions: model SF-R with hook-on mounting to the lift truck carriage; and model SF-Ri with integral mounting into the lift truck mast.
The fork positioner has sliding forks mounted on an upper chromed bar and lower rollers. It has bushings in the upper shaft bearing and lower rollers with greasers. The upper shaft bushings are protected with wiper rings. The simultaneous opening and closing of the forks is facilitated by the flow divider valve. The hydraulic fork positioning makes it possible to adjust the fork opening to varying pallet size, without leaving the driver's seat. The integral sideshift improves handling operation.
The integral mounting, replacing the original lift truck fork carriage, ensures an optimal residual capacity and, through customization for individual forklifts, provide the best possible visibility and smallest overall dimensions. Easy maintenance ensures long life for the attachment.
The robust structure and components are suitable for heavy-duty application as well as harsh environmental conditions.
Paola Baldini - Bolzoni SpA
Casoni di Podenzano (Piacenza), Italy
pbaldini@bolzoni-auramo.com, or visit our web site: www.bolzoni-auramo.com
Click here to view the Bolzoni Auramo Shopfront
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
